Question about Sony STR-DE595 5-Channel Amplifier
My Sony STR-DE595 has a problem with some output channels. The front right is very dim and the rear left is just gone. What should I look for when opening the unit?
robotek
  • 1512 Answers
SOURCE: Protect Mode With Sony str-de595
Hi snark63
Ypou have an intermittent problem that sounds to be heat related... the more work the amp does, the more heat generated by the output stages. This will be aggravating some poor solder joints that are cracked or dry. The unit needs some repair work done in these areas. If you have good experience with a soldering iron, the cure for this is to resolder the power stages of the unit, or any other solder joints that look to be failing.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 06, 2008
  • 4234 Answers
SOURCE: Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Posted on Dec 02, 2008
  • 85 Answers
SOURCE: playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Posted on Jan 09, 2009
petraman7
  • 1175 Answers
SOURCE: Sony STR-DE595 Sound not balanced
HI...
It will need tech service.
Check the Sony consumer site for who can do it.
Posted on Mar 27, 2009
Grubhead
  • 5449 Answers
SOURCE: The SONY STR DE595 goes
The protect thing is to do with an overload. It's more than likely that something in the main amp section has failed (perhaps a transistor on the big heat sink). The cause often speaker wiring touching together. You should look carefully at the this section for damage or burning. If you have a ohm meter you can test the transistors. If you place the probes on the terminals of each transistor and you get a responce like you had touch the probes together, you have located the source of the overload.
Posted on Sep 04, 2010
Can I connect a tape deck *and* a turntable to the Sony STR-DE595?
If your turn table has a magnetic cartridge it will not work,Becuase the ner recievers are not equip with a phono preamp, They are equip to only use a crystal or ceramic cartridge in the turn table.
Sep 29, 2012 | Sony STR-DE595 5-Channel Amplifier
I purchased an adapter for the mini jack - based on the sales associate advice - to connect my 3G iphone into my Sony DE595 headphone port. I decided to dbl check here before I plug it in. I see I...
Dont do it.
The jack on your phone is an Output. So is the headphone jack.
You need a stereo mini plug to (2) RCA type male plugs.
Then plug that into the AUX or CD jacks in the rear of the Sony
Sep 30, 2010 | Sony STR-DE595 5-Channel Amplifier
NO! It uses the same amps for a and b channels. and you could short it out if its wirer improperly.
Dec 17, 2009 | Sony STR-DE595 Receiver
The sound on my sony amplifier sounds too low inside the speaker.
Try getting the suround sound modes off and using straight stereo ,with no delays,or echos,
Jan 12, 2009 | Sony STR-DE595 5-Channel Amplifier
Playing ipod on sony str-de595 receiver
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
HI...
Aug 15, 2008 | Sony STR-DE595 5-Channel Amplifier
preamplifier or power amp internally but check your signal cables for shorts or breaks,if amp then is internal and needs to be serviced
Aug 13, 2008 | Sony STR-DE595 5-Channel Amplifier
SONY STR-DE305 FUSES
are these the speaker output fuses...if yes, they should be on back panel. if no, then are you also looking for board mounted fuses on the pc board?
Jun 01, 2007 | Sony STR-DE595 5-Channel Amplifier
Sony STR-DE595 5-Channel Amplifier Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
