Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
Thermostat flashes IL ? Model PTG-53PVN
Http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Posted on Feb 25, 2011
Thermostat is set @120 then drops to 65 and starts flashing. Water get cold. What is the reason . Thanks
Rheem Paloma tankless computer? No error code? One possible cause; Crossover caused by bad single handle faucet cartridge drawing cold water into line causing shut down of tankless burner?
Copy following links for resources:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment as needed.
Gene
hh
Aug 19, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
I am getting a IL code on my display
IL code is: water heater has lime deposits.
Tankless should be de-limed each year using white vinegar..
Search U-tube for "de-lime tankless heater" to see how to do this yourself, or call service technician.
There are special fittings that can be added to tank at the hot-n-cold ports that let you easily de-lime your water heater each year.
Typical manual shows error IL on page 33:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Typical manual also shows regular maintenance on page 29.
The word maintenance is used throughout the manual.
Research shows that regular de-liming will not restore full efficiency to tankless water heaters:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
Feb 15, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a poloma model PTG-74PVP hot water heater. This morning we went to use it and it will run a minute or two the flash alarm 35. We have had the unit for four years with no problems what so ever.
rtgl-74xp.jpg RTG-95XP Item Name: Outdoor Rheem Tankless Water Heater RTGL-74XP Item Price: $910-$1100 Gas Type: Propane Venting: No Item SKU: Rheem RTG-95XP replaces RTG-74XP Product Description: Rheem Tankless Water Heater RTG-95XP
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html
And this ---
This makes getting information hard to come by. Please use the link below for information.
http://www.rheemtanklessonline.com/contact.php
Feb 06, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
No hot water
contact rheem you probably have a circuit board problemb
Jul 24, 2010 | Rheem Tankless Hot Water Heater...
Starting unit very difficult
Check your thermocoupling, because it seems like it isn't sensing the flame.
May 09, 2010 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Oct 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
404 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
