Question about ASUS RTN12 4 Port 10100 Wireless N Router 300MBPS with QoS
Hi, I have my RTN12 Asus wireless router set to repeater mode so I can access wireless in all areas of my house. I see my network, connect, but then I get a system dump blue screne of death and my laptop reboots. I updated the Asus router to the latest firmware but I'm not sure what else I can do. Among other information, there is a message during the system dump about driver IRQL not less than or equal to.
    Problem Solver:
  • 5 Answers
IRQL is usually the following:
bad ram memory
bad software driver for example: video driver
run www.memtest86.com
if it's bad ram replace it
if its a driver update your video drivers
Posted on Apr 07, 2011
How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
I cant access the 192,168,2,1
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
Configuring a 3COM 3CRWDR200A-75 router as a repeater
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    How do i set bridge mode?
    Depends if you need a wireless or wired bridge?
    Here is some info for you.
    Infrastructure Mode
    With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
    mode provides wireless connectivity to multiple wireless network devices within a fixed range or
    area of coverage, interacting with wireless nodes via an antenna.
    In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
    data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
    Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
    mobile computing device moves out of the range of one access point, it moves into the range of
    another. As a result, wireless clients can freely roam from one Access Point domain to another and
    still maintain seamless network connection.
    Wireless Bridging Overview
    Using Wireless Router as a Wireless Access Point
    May 03, 2011 | NetGear RangeMax WPN824 Router
    When I try to set up my wireless network, I get the error message "Your static or dynamic IP address is wrong." I've never seen this message before. Anyone have any experience with this kind of problem?
    yes, in your windows you have your properties for your network card set with a static IP.
    1. Go to the properties of the network and see if you have the dhcp set to "automatic" same as for the DNS
    2. check your router for the same in the router usually going to a browser page and typing in 192.168.0.1 for most routers not sure what your is. check your router manual or go to the manufacturers page and get the instruction for your model.
    Oct 05, 2010 | ASUS RTN12 4 Port 10100 Wireless N Router...
    Create a password for wireless internet connection
    Hi. Open your browser and go to http://192.168.1.1
    the default username and password is admin / admin.
    Once you are inside the router, you will see on the left the menu such as network map, operation mode, advanced settings. Under advanced settings you will see the Wireless configuration where you can change the SSID (name of the wireless network) to any name you want. Then on the security you can select either WEP or WPA, i would recommend WPA and you set the password (letters and numbers or just letters) and save the settings and that's it.
    Try to do this on a computer directly connected to the router (via ethernet cable) because any change on the wireless will disconnect you.
    I hope this helps. Please do not forget to write and provide positive feedback for our fast/free support today. :D
    May 25, 2010 | ASUS RTN12 4 Port 10100 Wireless N Router...
    The ploblem is In need the solution of wire less network to build in the big house.
    I presume you need Internet access in this house using a wireless network.
    The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
    If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
    In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
    If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
    Nov 04, 2009 | Adapters.com Computers & Internet
    I am not able to properly set up my network with an ASUS Wl-500B
    Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
    Mar 23, 2009 | ASUS WL-500B Wireless Router
    ASUS RTN12 4 Port 10100 Wireless N Router 300MBPS with QoS Logo
    656 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
