Question about Home
Low water pressure from hand held shower wand .New home with possible mineral deposits
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Yes can disconnect your hose, at the shower head, their is a screen..check for deposits,
in addition you can soak the head in lime away or white vinegar.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
Delta tub valve how to replace
Depending on how old the valve is; it could just be held in by mineral deposits over time. Once the circlip is out, AND THE WATER PRESSURE IS OFF, just re-attach the handle and pull it out. The handle should give you the extra grip needed to get the assembly out.
May 09, 2010 | Delta & Single Handle Shower Faucet
Low water pressure. New installation, replacement
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I have an older Delta single handle shower scald guard. Water pressure from the cold side is fine. When I turn it to hot it slows to a trickle. After a minute or so it picks up slightly but it is then hard...
It sounds like it has mineral deposits in the hot water side. Try taking the internal valve parts completely out of the fixture and examine them. If there is any scaly (light grey) deposits, that would be the problem.
The solution is to soak all the parts in vinegar, which will dissolve the mineral deposits. It takes awhile to dissolve what has taken long to build up, so heat the vinegar, or put it all on a warm, not hot, surface to keep it more active.
I had this problem, and after cleaning it a couple of times with vinegar, I changed out the Delta to another brand. You could also use a water softening unit, which replace calcium and other metals with sodium, thus eliminating the mineral deposit problem.
Jan 25, 2010 | Delta & Single Handle Shower Faucet
I have a single handle Moen faucet in my shower. It has not been used for a while , now that my kids are home and try to take a shower there is little hot water coming from the shower. The cold water...
probable that there is mineral deposit's,scale buildup,inside. pull cartridge and look in valve body,turn water on to it and flush valve body real good.possible model #1222-if it's posi temp ,#1225 for reg faucet
Jan 01, 2010 | Moen & One Handle Tub & Shower Faucet
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
82 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
