Question about Whirlpool Washing Machines
My new cabrio washer has a soak cycle .if i use this cycle do i then have to select aq wash cylce AFTER the the soak cycle is finished in 29 minutes
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
SOURCE: kenmore washer machine cylce stopped in mid cycle
If your washer doesn't seem to work at all, check these:
  • No power
  • Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
 check these, if still the problem persists then let me know for further help.
Posted on Mar 22, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Posted on Apr 06, 2009
jsrock516
  • 5911 Answers
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Posted on Jun 11, 2009
  • 220 Answers
SOURCE: cabrio washer wont spin or finish cycle, gave ld
ld is for long drain,first did you pull the drain pump to make sure something wasn't stuck in it stopping it from turning or blocking the opening,it's the one on the right bottom as you standing in front of the unit,the on on the left is the recirculating pump,if so you can use a putty knife to open the top of the machine there are two spring clips on on either side about three inches in if you use a flashlight you can see where they are.push them in one at a time while lifting the top and be careful of the lid it will spring open as you lift the top.
 Once open remove the tub cover (the white plastic cover around the top of the tub) after removing the recirculating hose on the left rear corner.
Then remove the center cap on the wash plate(agitator)you'll see a 7/16 bolt through the center remove that and pull the wash plate straight up and off. once you've done this you can lift the entire spin basket out.
 Now you want to look in the bottom in the rear of the outer tub there is a cover over the drain with two screws in it if by this time you haven't found the issue (clothing stuck in the cover)then you may have a bad drain pump.
Posted on Sep 13, 2009
How do you take off lid lock on cabrio washer model wtw5600xwo?
Unfortunately the lid lock id there to prevent the lid from being opened during the cycle so there is no way to do it.
Mar 07, 2012 | Whirlpool Washing Machines
Run load of clothes still soaked when done
first check if you are runing the right program.
Or maybe the not spining cycle was pressed????
and finaly check the filter,water pump and clean.
good luck....
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer stops at a certain minute and won't proceed (i.e., it stops at 11 minutes for the low extract spin only cycle). Very frustrated! It worked fine for the service guy yesterday!
it may be in its pause cycle the washer pauses for about 2 minutes during certain cylce allow the cycle to continue some cycles go between agitation and soak
Jul 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Wash cylce
the programmer may be faulty.
Sep 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
197 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
