Question about HP LaserJet 2420 Printer
I have dark lines all the way down on the left side of paper. I replaced the toner cartridge, and still having the problem.
    Genius:
  • 1,570 Answers
It seems that the fuser film roller is damage and need to be replace. Only tecnichian can fix the problem because they will open the whole printer.Fuser film roller is color orange that u can see through. It is quite damage due to high volume of printing and this fuser film roller start to tear up from sideways. Or the black fuser roller is damage. Just try to clean this with alcohol and see if it works.
Posted on Dec 29, 2010
Scx4623f problem with printing right side dark and left side deem
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Feb 11, 2014 | Samsung SCX4623F AllInOne Laser Printer
I get a dark streak down the left hand side of every page.
It is either toner cartridge or fuser.
Print a few sheets of anything.
While printing, open the cover and pull out the toner.
Look down at the paper. If you see a dark streak, you have to replace the toner.
If the page is streakless, replace the fuser.
Jan 04, 2011 | HP LaserJet 6mp Printer
AL-1220.......dark (w/ residue ) toner line on left side of copy. replaced toner cartridge, but still showing. having to clean small piles of toner below drum even after replacing toner cartridge. am i...
I would have to say that you are having a problem with your drum unit and or the developing unit. Most likely the problem is in the drum unit. You have a line going down the page. I would replace the drum unit and try to clean below the drum unit... Good Luck..
Dec 26, 2009 | Office Equipment & Supplies
Dark band on left hand side of incoming faxes
Your toner cartridge is leaking toner onto the transfer roller. There is no cure except for replacing the cartridge.
Dec 10, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
A dark line vertically down the page is appearing on all pages printed. It is about 2/3 of the way from the left side of the page. Is it a cartridge problem or does something need cleaning and how do i...
This could be a either a cartridge problem or a fuser problem. The fuser is what melts toner to the page and when it goes bad it can cause image defects. The easiest thing to try would be replacing the toner cartridge, that will tell you right away what the problem is. However, if you don't have another cartridge to try, you can do what service techs call a "half test". It's when you let the paper get half way through the machine and you open the lid quick. The goal is to see if the image defect is before or after the toner cartridge. CAUTION when pulling out the paper for the toner that was not ran through the fuser will simply wipe off and you don't want to ruin clothing. If it's the fuser, have a service technician replace the fuser. The part number is RM1-0660-000.
Good luck and let me know if you have any other questions
Aug 10, 2009 | HP LaserJet 1020 Printer
Dark line down the left side of paper - changed the cartridge, seems worse...
When you say changed cartridge. Do you mean toner? It's much more likely the drum that's causing the problem.
Jun 24, 2009 | Brother HL-5240 Laser Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Black line
take out cartridge, look at he inside of machineis there toner on the left side of a thin glass, look at the fuser ( where it gets hot) are the rollers O.K. ?
Nov 27, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Paper light on...!!
Turn the printer off. Take out the toner drum and cartridge. Remove the toner cartridge by pressing on the blue lever on the left side. Check for paper. Replace the cartridge. At the rear of the toner drum is a blue slide lever on the right side for cleaning the corona wire. Move the lever back and forth, left and right, about 30 times. Reset lever to far right side with arrows lining up. Set the drum and cartridge aside. Remove the paper tray and look inside for a jammed sheet of paper. Flip the back lid down and check for paper. Snap the back lid up, replace the paper tray, and replace the drum and toner cartridge. Turn the printer on. Press the ready button 3 times quickly. It should print a specifications sheet. If it does, try printing from your computer. If this did not help, Brother tech support is 1-800-276-7746. Robi
Nov 10, 2006 | Brother HL-2040 Laser Printer
HP LaserJet 2420 Printer Logo
185 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
