Question about Breville CT75XL 4-Slice Toaster
Is there a way to disable the beep on the breville/ikon 2 slice toaster? This beep sounds when the toast is ready and is very annoying. Thanks
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
  • 69 Answers
SOURCE: Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Posted on Sep 25, 2007
Alan ang
  • 24 Answers
SOURCE: Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Posted on Feb 24, 2008
  • 87 Answers
SOURCE: Breville classique toaster
burned out element . replace unit.
Posted on Jul 12, 2008
EwingElect
  • 276 Answers
SOURCE: Can you turn off the annoying beep when toast is
Hate to tell you this, but from the looks of their manuals on the similar Australian model, then no.
"When the toasting cycle is complete, the toaster will ‘beep’ to indicate that the toast is ready. No need to wait while the toast cooks."
Posted on Dec 05, 2009
Toaster lever stuck in down position
I just fixed my Breville CT75XL Ikon 4-Slice toaster which was stuck in the on-down position. Wife said it heated up the whole kitchen and finally unplugged it. There are tamper proof screws as well as needle nose pliers needed to disassemble what appears to be a unit that is not intended to take apart or service. All I did was release the mechanism that holds and powers on the device then scrape the metal contacts with an emery board. Unit works but this buys me time to find a replacement. It won't be another 170 dollar disposable Breville made in China that's for sure. Only got 3 years 4 months use, family of 2, which is pathetic.
Aug 16, 2013 | Dualit Kitchen Appliances - Others
Breville beeping too loud
The beeping sound is annoying and mostly unnecessary. Unfortunately it can't be turned off. The only way to "fix it" would be to remove or disable the Piezo buzzer. I tried doing this, but disassembling the oven to reach the pcb control board ,where the buzzer is located, is complicated. You can take the top cover off using a Philips screw drive. But reaching the pcb board is tedious. So I gave uP and reassemble it. If someone has a better idea or method , please share. This is a great oven except for the annoying beeping. Even my dogs are afraid because it is the same sound that my invisible fence has and they think that they are being warned.
Mar 28, 2013 | Breville BOV800XL 1800 Watts Toaster Oven...
Left side does not drop toast down, elements work.
I had to take my toaster outside and clean out the sidees of each slot. There was debris baked on and it had the wire frame stuck. Once I cleaned, scraped and emptied out the junk, the toaster works fine.
Jan 25, 2011 | Breville BTA840XL 4-Slice Toaster
Lever stopped working
mcdevito75 here, Sounds like the return spring on the laver is mis-aligned, see any appliance repair shop in your area.
Jun 28, 2010 | Breville CT75XL 4-Slice Toaster
Dec 03, 2009 | Breville CT75XL 4-Slice Toaster
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
May 12, 2008 | Breville CT20 Retro Classic 2-Slice...
Breville CT75XL 4-Slice Toaster Logo
205 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
