Question about Dishwashers
How do i unlock my frigidaire dishwasher model FDB1100RHM
3 Suggested Answers
  • 148 Answers
SOURCE: my frigidaire fdb1100rhm dishwasher detergent
Check for correct water pressure to the dishwasher. Could be a restriction in the 1/4" water supply line.
Posted on Feb 01, 2011
heatman101
  • 43501 Answers
SOURCE: Frigidaire dishwasher won't dry dishes.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 05, 2011
DW makes a lot of noice when it's washing....squealy, whiney noice...very loud.
Hello Summer Summer - Often if the dishwasher is making a loud, squealing noise then it is recommended for the wash motor to be replaced. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directly to determine what may be causing the issue at hand.
Mar 12, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Model Number FDB1100RHM0 Dishwasher does not do anything. All switches on front panel seem to work and the water is turned on
proceed with this step:
Power from the house
test for some blown fuse or c. breaker reset.
Door switch
if the swtich door if open or defective, will not start the machine see the wiring diagram attached.
Wiring
see for wires, burn, breaker or loose repair.
Timer or selector switch
test the timer, for contact dirty, or corred, clean, and tigh the wires loose see the diagram attached.
May 07, 2012 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire dishwasher won't dry dishes. Less than two years old. Seldom used. FDB1100RHM. Could this be the heating element? Could this be something we could fix?
heatman101
Sep 05, 2011 | Frigidaire Dishwashers
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
Sep 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Doesn't fill with water
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 07, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Dishes won't rinse properly, always leave a residue on them. Dishwasher is brand new
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 14, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My frigidaire fdb1100rhm dishwasher detergent dispenser clogs as well as overfill protector
Feb 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
This dishwasher leaks in the front. Is there a fix I can do on this?
You need to determine if it is the door seal leaking or if the leak is coming from under the machine. If it is the door seal, it will need to be replaced. If the leak is elsewhere it will have to be repaired accordingly.
Jan 28, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
I have a frigidaire diswasher Model: FDB1100RHM (silver mist) have had it about a year. We just had to disconnect it to replace a drain (linked to my sink). After we hooke dit back up, when we plugged it...
Suggests a power failure. Check loose wiring at the junction box where power supply is connected. Check white and black wire connection to electronic control board. See if flipped switch in fuse box for line to dishwasher.
Just one possiblity. Others include burnt out heating element or bad pump. Time to check warranty for service call.
Oct 07, 2017 | Frigidaire PLD4555RFC Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
