Unable to get any sound from 13" Tinkerbell TV F1310A TVD. Tried multiple inputs and also tried the headphone jack, no sound at all.
  • 4 more comments
  • Elio Dec 30, 2010
    Thank you Az,
    I am able to increase the volume on the TV to 100 (the max value the TV will allow) and I hear static when there should be sound.
    Ive also unplugged the TV for a few minutes (for the third time) and again tried multiple inputs. Its a brand new TV, never used, right out of the box.
    Standing by for your advice!
    Regards,
    Elio
  • Elio Dec 30, 2010
    Thank you both for your assistance!
    I will do as suggested and bring it back and swap it out for another new TV. Much appreciated for the advice, I will not open it up! Will leave it alone for once and swap it out.
    Happy New Year!
  • Elio Dec 30, 2010
    Thank you Az very much,
    Am taking your advice and will bring it back for a new replacement. As much as Id like to open it up and try and fix it, I'll follow your lead to not touch it.
    Take care and happy New Year!
  • Elio Dec 30, 2010
    Solution was very helpful. My support expert responded quickly and very profesionally.
  • Elio Dec 30, 2010
  • Elio Dec 30, 2010
    Yes, thank you. I just accepted your solution and left positive feedback.
    Best regards
  • 11,800 Answers
You must do a simple test to determine the origin of the problem: put the volume to the maximum and listen to the speakers.
If you can't raise the volume or it appears muted whatever keys you pres then the control processor of the tv is damaged. Since you will have to replace the entire mainboard to fix it and that would cost more than a new tv it means that the tv is dead , replace it.
If you can raise the volume but nothing gets heard then the audio amplifier chip from inside the pc has failed and must be replaced. This is a relatively complicated job for a repair shop - it will cost you roughly $100.
If you can raise the volume and a buzzing sound is heard it means that the AV switcher chip (its Audio part more precisely) has failed and you will have to replace it at a cost of about $120.
Posted on Dec 29, 2010
  • Azrael SRL Dec 30, 2010
    If you hear the static and the volume is active in means that the problem is in the AV switcher circuit - the circuit that manages what source of AV signal is used: the internal tuner or one of the external inputs - hardware (actual part) not software (setting) fault. Since this is a brand new tv you must return it - do not attempt to fix it yourself or you'll void the warranty.
    In that case would you select my reply as the one that answered your Question?
  • 6,993 Answers
I believe the TV is under warranty and even if it isn't, i would suggest you return the TV and replace it another. This time, test the TV before leaving the store.
I believe the TV is having a factory problem. It seems as if the sound IC/card of the TV is defective and that's why there is no sound coming out of the TV. You have done well by testing the headphone. As long as sound does not come out from the headphone jack, it means the problem is from the internal part of the TV and the sound IC is the right area to suspect.
If you open the TV's back cover, you warranty will be void and they won't receive the TV back from you. So take the TV back like that.
It doesn't pay if you have to spend extra cash fixing this TV which is suppose to be brand new.
Compliments of the Season!
Posted on Dec 30, 2010
  • Walesarumi
    Walesarumi Dec 30, 2010
    You are welcome! Happy new year to you too
  • Walesarumi
    Okay
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
Sharp aquos audio input jack not working
That 3.5 jack only works when the TV input is selected for PC. Try an HDMI or Hi def cable connection to the TV
Dec 14, 2013 | Sharp Aquos Televison & Video
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Input jack on my hp541 kicker headphone's sound comes and goes. I have tried multiple cables, If I wiggle the cable around it works in one speaker sometimes both.
Hi hotrodjayrod,
If the symptoms remain the same after trying another headset, this kind of fault is caused by bad solder joints in the earphone jack itself of your unit. This is due to frequent inserting and pulling the headset plug. To resolve the issue, the earphone jack must be re-soldered. You have to open the back cover of your player and using a pointed soldering iron, re-solder the joints.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Kicker HP541 Headphones
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
H/p input on
I had a similar problem and solved it by simply blowing in the headphone jack (h/p input).
Dec 20, 2007 | Denon AVR-1907 Receiver
Audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Sep 03, 2006 | RCA F36689 36" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
