Question about Vivitar Cameras
My vivitar 410 is saying the memory is full but it has a brand new sd card???
    Scholar:
  • 66 Answers
Hi
There are two Vivitar DVR-410 models. A model released in the early 2000's and a newer version released in 2010.
If you have the the earlier DVR-410 model then it will probably only use low capacity SD cards - e.g. 512Mb or lower. if you are trying to use a higher capacity card on this model it may well show that it is full.
If you have the modern 2010 version of the DVR-410 then it can uses SD cards upto 2Gb and SDHC cards upto 16Gb
You should also check the card you are trying to use is formatted, and the lock switch is not set.
Hope this helps
David
Posted on Dec 29, 2010
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: When I turn on my
When your internal memory is full it means that you have taken an amount of pictures that has filled up the memory of the camera. You will want to buy a memory card (such as this) to store the pictures you take on your digital camera
Posted on Jun 01, 2011
Vivitar camera isnt reading sd card
What type and size memory card? Is it formatted?
Dec 22, 2012 | Vivitar Dvr-410 - Camcorder - 1.3 Mpix -...
I CANNOT GET MY NEW MEMORY CARD TO WORK
Try connecting ur camera to your computer with the SD card n sync the camera and it should give u the option to change settings and sd card settings.
Sep 14, 2012 | Vivitar Vivicam T324N Digital Camera-...
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
Try to take a pic and says card full even with a brand new SD card
Card might have the lock on it see included diagram, also a new memory card need to be formatted to the camera so it cam properly communicate with the camera it's being used in. Also after each picture download the memory card should be formatted to clean and make the camera and memory card compatible once again.
Diagram slide switch towards the top closest to the gold contacts
Jan 09, 2011 | Vivitar ViviCam 8025 Digital Camera
Do i need a sd card to operate my vivitar 410
Yes you do. The Vivitar DVR 410 requires a standard SD memory card (up to 16GB) to record images or video. The 410 is NOT designed to accept SDHC memory cards so make sure you purchase the proper type.
Jan 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
Memory full
You will have to check this out on the manual. There is a full manual on the software CD
Aug 25, 2007 | Vivitar ViviCam 4100 Digital Camera
Cameras Logo
306 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
