Question about Ovens
I have a hotpoint model RB787WB1WW. Its over 8 years old. Went to self clean. Everything going fine till I had to open the door. The latch is still locked.(can not move to the left to open) I let it cool for a few hours and for a whole day and even pulling the plug out for the night, (8 hours). I could still not move the latch to the open position. Did the self clean again hoping it would reset and open this time. But still can not open latch. When I turn the knob to heat the oven the self clean light comes on.
SOURCE: Door won't open
Try holding the Off/Cancel button.
Posted on Apr 14, 2007
SOURCE: Amana gas range bake burner does not heat
AMANA GAS RANGE
MODEL #ARG7301WW P1143323NWW
SERIAL: 9710232146
Hi Tamiw and oh Mighty Guru Text,.
I had the same problem with the oven not emitting a flame from the burner, but at the same time- the ignitor lit up and heated the oven enough to say it is 'HOT'.
It seems to be an intermittent problem';sometimes it emits a flame while other times I would wait 11 minutes with the dial set to 400 to emit flames.,
Detailed description of PROBLEM and steps I have already taken:
The Ignitor always turns on, and lights up.
1. After the initial cleaning of the burner vents with a coarse bristle cleanibng brush, I turned the oven dial on and everything seemed to be working fine. ie: ignitor turned on, blue flames came out of the burner and maintained a constant temperature.
Then,-after I had performed a "self-clean", to see if this feature would now work, it did! I used the oven for bake a few hours later......
The same symptom ocurred, the ignitor went on, but no flames were observed, YES, there was heat coming from the oven, but NO flames coming out of the burner mechanism:
The Ignitor turned on, but no "flames" were observed. Heat was given off from the glowbar, but no flames. I did NOT smell any gas, only what an inside of the oven smells like after cleaning.
From my records, I had replaced the thermostat about 4 years ago.
Today, I tried this again, and sure enough the ignitor lit up, and the burner was emitting blue flames. But when I put the "FLAME SPREADER" back, and turned the oven OFF, then on again to bake cookies, the oven didnt seem to heat up completely.
Could this be intermittent? or Could the flame spreader hamper the burner operation? (Earlier when I loosened the nut on the flame spreader the bolt broke. I tried to replace with another nut, but the bolt/screw was too short for contact.) Could this contribute to the problem? Does the flame spreader need to be tightly screwed for the burner to function correctly?
One thing I am noticing, is that it takes LONGER for the flames to come thru (than the average 90 seconds)
For example: Ten minutes ago I set the dial to 350. 5 minutes went by, and no flames, then set the dial to 450 after ten minutes oven was hot, but no flames?
I THEN SET TIMER FOR ANOTHER 5 MINUTES, AND 1 MINUTE LATER THE FLAMES TURNED ON. Total preheating time for flames to come on today = 11 minutes.
I have a "MULTIMETER" from DIGITEK Model # DS830B+ This should work to see the amperage, but I dont remember how to test it! the MAX OHMs are 2000, MA 200 Max, 500V
http://www.digitek.com.hk/
Can I use this to test the current? How would I do this?
Lastly, HOW DIFFICULT IS IT TO CHANGE OUT THE IGNITOR> Meaning do I have to shut off the gas as well as the power circuit?
Ok, hope this helps.
Thanks again,
Callie T
Posted on Jul 19, 2008
  • 899 Answers
SOURCE: Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Posted on Oct 13, 2008
  • 338 Answers
SOURCE: Self clean doesn't start
i would pop the top up and see if there is a bad switch on the handle that locks the oven.
Posted on Feb 13, 2009
  • 17 Answers
SOURCE: Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Posted on Sep 27, 2009
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Door won't open
Apr 12, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
