Question about Samsung Ultra-Slim WEP350 Bluetooth Headset
Blue tooth is fully charged .but when i take it out of the charger it will not turn on?
It doesn't seem to keep the charge. does that mean I need a new charger or a new headset?
Sounds like the battery is not holding its charge.......you can rejuvenate the battery by fully charging and then fully draining til it goes off either by leaving on or using! Doing this a few times will allow the battery to fully charge and hold the charge better!
Feb 04, 2015 | Radio Communications
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Motorola Razor will not charge
turn the lights off in a room while the phone is on and see if you can see a light coming from the phone while it is closed and on.if you have a new battery did you let it fully charge before using.make sure the blue tooth is turned off.
May 13, 2010 | Motorola Mobility RAZR V3
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 | Cell Phones
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Blue tooth connectivete problem
Amii hello,
I would try shutting the phone off.
Then, remove the battery for a few seconds. Put everything back on, and turn on the device.
This is a known bug with many SE phones.
IF possible, I would also try to update your firmware.
Oct 29, 2008 | Sony Ericsson K800i Cellular Phone
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Motorola H550 bluetooth headset
i turned it back intno the store got a refund and went to a different headset. sorry to bother you but i think it had to do with the battery in the headset
Feb 24, 2008 | Motorola Mobility H500 Wireless Headset
Samsung Ultra-Slim WEP350 Bluetooth Headset  Logo
29 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
