Question about Microwave Ovens
During the cooking for our Christmas dinner the temperature started declining from the 350 degrees to 280 degrees. We tried the top burner to make sure the stovetop was working and the whole thing shut down. We have put the plug back into the socket twice and tried to get the clock started to hopefully "kickstart" it again. It let us put the time in, but would not go any further. Please help with a suggestion to fix this. It will cost us $79 just for a repair man to come here; then everything else will be extra, of course. This is our second Maytag in 9 years! Not a good average, is it? Jane Ackerman
  • 312 Answers
Hi Jane,
Ouch! Sorry about the Christmas dinner. I sounds as though the circuit breaker tripped.
First, find the circuit breaker panel.
1 Check to see if a breaker has tripped. These breakers are double sided because stoves are
240 volt appliances, like the water heater or the house heater. There is a bar that connects
two single breakers together. The breaker will be slightly off center to the other breakers if it is tripped.
2 If it HAS tripped DON'T TURN IT ON YET
3 Go back to the stove and plug it in.
4 Turn on a top burner(not the one that may have tripped the breaker) preferably one that you know works that you don't use very much.
5 Go back into the garage and turn on the breaker.
6 If it goes on OK go back to the kitchen. You have done the first diagnostic test.
7 Check the burner to see if it is getting hot. If it is, turn it to high and then turn on the burner that blew the breaker in the first place. See if it blows the breaker again. If it does not. Turn on all of the burners that you know work. You have now done several Diagnostic Steps that are important.
8 If one of the burners trips the breaker, you have one of the culprets. If not, GREAT.
9 Shut off all of the burners
10 DO NOT TURN ON THE OVEN
11 Open the oven door and look very carefully with a flashlight at the bottom bake heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced.
12 There is one other rare possibility, but it would not have blown the breaker. Many ovens have clock baking timers. These timers will, shut down the oven. If someone adjusted the timer and didn't turn the knobs in the exact right position. It will ruin the party shutting down the oven at the worst time. But it won't shut the stove top burners down.
IF YOU HAVE FUSES INSTEAD OF BREAKERS
If you have fuses instead of circuit breakers, Find several of the large cylinder shaped fuses to conduct the diagnostic tests I suggest. They are usually available at home depot.
RARE PROBLEM
One last but very rare occurence with breakers is their specifications sometimes change over a long period of time. If that is the case, they will trip and lower and lower overload levels. Simply Replace.
I hope this helps,
Good Luck
Best Regards,
Mark
Posted on Dec 29, 2010
I am cooking a roast beef dinner for Christmas I bought a 13lb chuck boneless and I need to know how long to cook in in a traditional oven.
5 After browning the roast at a 500°F temperature in the oven for 15 minutes, reduce the oven temperature to 325°F. To figure out the total cooking time, allow about 11-12 minutes per pound for rare and 13-15 minutes per pound for medium rare.
Really, you need a probe thermometer. Leave it to rest for 15 minutes after you take it out of the oven, loosely tented with foil. I am a chef!
how long to cook Google Search
Dec 24, 2016 | In Microwave Ovens
Is the sharp above range microwave model r-1871t recirculating?
According to the Sharp product site, http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models/R1871.aspx , the R-1871 is a convection and microwave oven. The manual describes using the convection oven feature on page 18 (page 20 of the PDF). The direct link to the manual is: http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R1872.pdf . The convection button is on the top left in the middle group of buttons. You use the numeric power level buttons to set the oven temperature. When you program convection cooking, the 1 button will bring the oven to 100 degrees F. The 6 button gets the oven to 350 degrees F.
I hope this helps.
Sep 18, 2015 | Sharp Microwave Ovens
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
Have a Proctor Silex small crock pot, no manual. Setting are Off, 1, 2 and "AutoShift". There is no timer. How can it be set to (1) be sure to cook the food long enough and (2) stay on / keep...
You can find a Use and Care Guide for your product at the following website. You will need to locate the model number of your crock point. Select Slow_Cookers in the product field; Select your model number and click on Submit.
A pdf file of your Use and care Guide will be provided; note they are scanned files and some are of poor quality.
Model 36400 has a similar control to your model. The Guide provides a table of the time to cook at settings 1 (low), 2 (high) and Auto Shift. Auto Shift starts at the high setting and then decreases to the low setting. The time to cook at Auto shift is in between the time taken at the low and high settings. The low and Auto Shift settings are designed for long cook times at a simmer. On the high setting some foods like soups will come to a boil and may need stirring during cooking.
The crock point has no auto turn off and will keep foods at a simmer when on the low or Auto Shift settings. With some practice you will learn how much time this will take for various foods.
The sure way is to use a tip sensitive digital instant-read thermometer to check the final temperature of the food. Check according the guidance provided by the Partnerships Food Safety Education:
http://fightbac.org/safe-food-handling/cook/127-cook-heat-it-up-chart?format=pdf
Feb 06, 2011 | Microwave Ovens
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
