Question about Canon imageRUNNER 6020 Copier
Where do I find waste toner container on the imagerunner 6020
  • Canon Expert
  • 122 Answers
See at the bottom right side of right panel there is a ractangle vertical panel take out the panel behind it there is waste toner container.
Posted on Jan 06, 2011
Fehler e00013 000
A E00013-000 deals with the waste toner feed screw being clogged. You will have to pull out the drum unit & vac out the packed toner in the waste toner feed screw. It is a messy job..... I hope you are a tech???? You also, need to make sure that the switch in the rear of the copier is in the correct position and also, look for any stripped gears??? Good Luck
May 07, 2013 | Canon imageRUNNER 6020 Copier
Where is the waste toner container on a canon 7065 copier fax machine
waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
How do i replace the waste toner container on a Canon Imagerunner 4570?
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
Feb 02, 2010 | Canon imageRUNNER 4570 Copier
Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Jan 15, 2010 | Canon imageRUNNER 5570 Copier
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon Imagerunner C3100
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Jan 10, 2008 | Baby Gear
Canon imageRUNNER 6020 Copier Logo
164 people viewed this question
old marine
old marine
