Question about Kenmore Dryers
No heating, but everything else works fine - Kenmore Dryers
  • Barrett Palumbo
    Barrett Palumbo Dec 29, 2010
    Sorry to read about your issues.
    But you really need to give us the make and model, of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on..
  • mgv14 Dec 29, 2010
    It's a Kenmore 70 series (electric)
    Model # 110 66732501
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 29, 2010
  • 1,772 Answers
We
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
hi there,
can you provide the brand and model # off your microwave please?
thanks
Sep 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Dryers Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
