Question about Dryers
How to open the dryer to get at the belt - Dryers
  • Dryers Master
  • 7,482 Answers
Http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Dec 29, 2010
Pluged in push star says its working not working
you will need to open the dryer up and see if the belt is off or broken:
opening up a dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagram:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 26, 2011 | Dryers
I have a maytag neptue dc dryer & I need to know how to replace the belt
open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
May 22, 2011 | Dryers
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
I need to replace tumble dryer belt
how to open dryer:
belt diagram:
note Kenmore/Whirlpool are the same
Mar 19, 2011 | Dryers
Belt broken
how to open a dryer:
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Jan 10, 2011 | Whirlpool Dryers
How to open to get to the belt
dryer cabinet how to open:
belt diagram:
Dec 23, 2010 | Amana NDE2330AY Electric Dryer
Kenmore 400 series dryer heats but does not turn, how do I access drum belt
to open dryer:
belt:
Dec 11, 2010 | Kenmore 400 6942 Dryer
How do i replace the belt
open dryer up: http://www.partselect.com/dryer+ge-open-cabinet+repair.htm
note the routing: http://www.applianceaid.com/images/belt-config.JPG
I would check eBay for a dryer belt as it took two days and $4.95 for my belt. Good Luck Tim
Nov 29, 2010 | General Electric DHDSR46EGWW Dryer
The belt on my dryer broke. How do I replace it
open a cabinet:
belt diagram:
Hope this helps, you may want to clean out all the lint inside the dryer since it is open. Tim
Nov 27, 2010 | Whirlpool ET8CHEXSQ Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
