Question about Dishwashers
Code E1 Problem on LG Dishwasher LD-2120WH - Dishwashers
5 Suggested Answers
  • 4793 Answers
SOURCE: how much salt do you have to place into LG
just use dishwasher tabs.no salt needed or rinse aid,lots greener too...
Posted on Sep 19, 2009
  • 106 Answers
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
SOURCE: I have an LG dishwasher,
I've just solved the same problem on my 2120. It started when the pump motor bearing failed and continued after I'd replaced the bearing. According to my handbook the E1 fault is theoretically a water leak but practically it is that the pump is not delivering enough water. In this case the failed bearing had allowed the shaft to wobble about and damage either the rotor or the inside of the pump (it's sealed so you can't strip it). Solution was to replace the pump.
Paul H
Posted on Nov 28, 2010
Dishwasher LG ld-2120wh has a F on the Auto switch, what does this mean
it means that is testing the washing cycle , It uses only what it needs to use of your powerball dishwashing detergent by testing the water . The F is displayed while it tests the water in the dishwasher to determine how much detergent it needs.
Apr 15, 2014 | Dishwashers
Dishwasher LG ld-2120wh have F on the Auto switch, what does this mean
F is displayed when the dish washer is testing the water to see if more dishwashing powder should be used when in Auto mode. To do with saving the environment to use the least amount of detergent
I have an LG dishwasher, Model LD-2120WH and lately it starts" -- water goes in but it throws up a E1 message on the display screen, send off an alarm and stops
Paul H
Nov 08, 2010 | LG Dishwashers
E1 fault no manual
Hi, use this table to find and know more about codes.When you get into the link,scroll you will see all codes and solution.
(repairclinic.com/0078.asp).
Take care.
Jun 14, 2010 | LG 24 in. LD-12BW5 Free-standing...
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
How much salt do you have to place into LG
Sep 19, 2009 | LG Dishwashers
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
534 people viewed this question
Top Dishwashers Experts
Owen Barnes
