Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice works but no water comes out. when you press the water dispencer the waterleakes on the floor. I've been told I have a broken bladder, but I don't know where to locate it? Nor how to replace it.
  • pammerv Jul 13, 2008
    No water dispences from the door
  • Anonymous Jul 23, 2008
    try unplugging and then plug back in after a minute. I had the same problem and it must have just reset the system. Good luck.
  • 125 Answers
Remove the toe kick, on the t side you will see a connector where two water lines meet, if the water is leaking there, push the two lines into the connector and then pull back on them to make sure they are sealed. test to see if it still leaks, if it does push the red or blue ring around the line in, while doing that pull the line out of the connector, repaet for the opposite side. use a razor or sharp knife and cut about a half inch off each line, make sure they are flat, push them back into the connector, and pull to seal, if it still leaks replace the connector. If the wateer is coming out of the freezer door replace the water line that goes through the door.
Posted on Jul 19, 2008
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool side/side ice dispencer not working
I had the same problem, however, the ONLY fix was to call the repair guy and get a new part. I took it out, defrosted the unit thinking ice was in the gear mechanism, lubricated and re-installed it to no avail. The repair guy had SEVERAL of these geared mechanisms in his truck so that told me THIS HAPPENS A LOT. Good luck.
Aug 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
130 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
