Question about Sharp 64LHP4000 64" Rear Projection Television
I HAVE A SHARP HDTV MODEL 64LHP4000. When you turn it on, the picture rolls for several minutes. Eventually it stops but it seems to be getting worse. Also, we need a romote... this was given to me by my parents, it has been sitting for about 5 years. When it finally comes on it looks great, except we need to fine tune the colors and cannot do it without the remote. Thanks for your time. Mickey
    Top Expert:
  • Sharp Master
  • 42,874 Answers
Fixya does not sell replacement remote controls.
Posted on Aug 05, 2017
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
  • 53 Answers
SOURCE: LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Posted on Mar 18, 2008
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
dsacco86
  • 1077 Answers
SOURCE: need help programing a directv remote to a sharp tv, model # lc46sb54u
I know what you mean. :(
I couldn't get mine to work with my Emerson TV. No codes worked.
You may have a chance with yours. Try this link here to get and program the codes:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020#
Then if does control the TV, hopefully the input button on the remote will work.
Posted on May 12, 2009
ginko
  • 19396 Answers
SOURCE: Sharp Microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on May 16, 2009
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Dec 09, 2012 | Philips 50PF7321D 50 in. Plasma HDTV
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
Makes buzzing sound and no picture lamp?
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Dec 24, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
SharpVision Model 64LHP4000: Hear a clicking sound coming from back of tv, solid red light, on front, comes on but no picture or sound.
Is your antenna connected or you cable satellite hook up to the TV? you need a signal of some sort to activate the TV circuits. Try a vcr or dvd player hooked to the set put in a tape or a dvd!!
Jun 30, 2009 | Sharp Televison & Video
Have sound, lose picture. D52W23
sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rolling screen
This may be a vertical hold control problem I'm not sure where the Vert. Hold potentiometer is on the mainboard. I would see if you can find someone who can locate it and adjust it.
Sep 15, 2007 | RCA HD52W56 52" Rear Projection HDTV
Lamp problem?
your picture processor is broken. we have the same tv, after 1 year problem started. we got a tv tech out and he looked at it and said it would cost $1800 to fix and this is after we bought a $400 bulb from sharp. this problem is in many of the same tv's of this exact model as we've invstigated and sharp is unwilling to help. there should be a classaction suit or recall for this exact tv.do not buy bulb , it will not work
Aug 18, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 64LHP4000 64" Rear Projection Television Logo
43 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
