Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Cartridge? problem printer says magenta cartridge empty when not, then no catridge at all even when inserted. will not clean when selected on menu either. tried the reset procedure.... no dice...
  • 1 more comment
  • Anonymous Jul 16, 2008
    It says that there's no cyan and magenta cartridges and refuses to print anything even in black and white because of it. It doesn't want to clean it's head or do anything.
  • Anonymous Mar 21, 2009
  • Anjon Datto
    Anjon Datto Jul 21, 2017
    To secure the restrictive privileges of Printronix, Inc., you consent to keep up the Software Product and other restrictive data concerning the typefaces in strict certainty.
    b. You concur not to copy or duplicate the Software Item.
    c. You should not sublicense, offer, rent, or something else exchange all or any bit of the Software Product isolate from the printer, without the earlier composed assent of Printronix, Inc.
    d. You may not adjust or get ready subordinate works of the Software Product.
    e. You may not transmit the Software Product over a organize, by phone, or electronically utilizing any means; or figure out, decompile ordismantle the Software.
    f. You consent to keep classified and utilize your best endeavors to avert and ensure the substance of the Programming Product from unapproved exposure or utilize.
    3. Exchange. You may exchange the Software Product with the printer, yet just if the beneficiary consents to acknowledge the terms and states of this Agreement. Your permit is
    naturally ended on the off chance that you exchange the Software Item and printer. Restricted Software Product Warranty Printronix, Inc. warrants that for ninety (90) days after conveyance, the Software will perform as per details distributed by Printronix, Inc. Printronix, Inc. does not warrant that the Software is free from all bugs, blunders and exclusions. Cure Your elite cure and the sole risk of Printronix, Inc. regarding the Software is substitution of damaged.
    For more info pease visit
If you are using or have used third party generic ink cartridges or refilled ink cartridges, the Cartridge Sensor printed circuit board may have been damaged. We have found that some third party generic ink cartridges leak onto the ink cartridge sensor circuit board causing an electrical short of the ink cartridge sensors. The damage from the leaked ink results in the machine displaying NO CARTRIDGE because the machine will no longer recognize the installed ink cartridge(s). Genuine Brother ink cartridges do not cause this issue because of the unique design developed to fit specifically in the Brother products. As long as a Brother cartridge has not been refilled, the Brother cartridge will not leak.
Posted on Jul 22, 2008
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
Right catridge not correct
Make sure you are inserting the correct cartridge versions for your Lexmark X5470 printer. Color cartridges compatible for your model are #33 and #35.
Try to re-insert the right cartridge into the printer. If that doesn't help, remove the right cartridge from your printer again. Close the printer cover. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, re-insert your right cartridge. Close the printer cover and check for any errors. Try to print a document to verify that the problem is fixed.
If the problem continues, try to do the Clean Cartridge function from the printer operator panel. On Copy mode, press the Menu button > select Tools > select Maintenance > select Clean Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print a document to verify that the problem is fixed.
If the error still appears on the display screen, you probably have a faulty cartridge. Please replace it with a new genuine Lexmark cartridge.
Sep 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
HP 8500 OfficeJet Printer Display keeps showing a message that my Magenta catridge is empty and need to be changed even though I changed it
Try cleaning out the cartridge slot. This is very often the reason that your printer isn't recognising it, because it's dirty.
I hope i was able to help.
Jul 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Magenta not working when printing colors
try to wipe it in a wet cloth to remove the clogs on the nozzle that avoid it from jetting...load again your catridge on the carrier or cartridge holder....
and run maintenance page on it ...go to your printer panel and select maintenance and then select clean print a maintenance page..or maybe your magenta has have a low ink condition..
thank you for using fixya..
good luck..
May 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson Aculaser Need to bring faulty cartridge to front
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner.
Apr 06, 2009 | Epson Aculaser C1100 Printer
6210 Not Print Magenta
try to clean BOTH copper contacts of the printer and cartridge
- and try to run again the alignment page.....
- if the issue still persist it is a hardware issue...
Aug 08, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Near empty Magenta
You have to press 1 (for Yes) when the display asks if you have changed the cart.
Take cart out and insert again. Watch display!
Feb 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
305 people viewed this question
James Cagle
James Cagle
Jim Keysor
