Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Playstation 3 won't connect in hdmi. flickers when put on channel and then says it is incompatible
Check that hdmi cable is connecting and is in good shape, may need new one
Posted on Dec 29, 2010
Certain channels on the tv flicker when I change channels and the screen will black out for about 3 seconds as if it's seraching for the signal. The flickering and blacking out is very intermittent. I have...
Rogers cable is using what they call "switch digital" this allows more channels to be placed on the platform they are using to give you more stations. This basically means people on the same line that you are, are not watching this station so they put that station "off" until someone tunes into it.
Nov 20, 2010 | Televison & Video
Having trouble changeing my ps3 to hdmi
if your tv is like mine ....
your tv may have a several imputs in the back so it may have a channel hdmi1 or even hdmi6. juss make sure that the channel your own matches the imput number on the tv
Dec 27, 2009 | Video Game Consoles & Games
When i put the ps3 on, the picture is grainy and flickering
prolly the problem is the HDMI clabe, try changing your HDMI cables, reply back with deatils.
also try changing video modes.
Mar 28, 2009 | Sony Playstation 3 (PS3) Console
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 connection
If I remember correctly the Playstation 3 is set to display through the analog output as default.
Plug in your HDMI cable, and plug in the analog SCART cable that came with the box, put your TV on the analog channel that matches the SCART input and start the Playstation. Once you complete the initial Playstation setup you can go to system settings and change the video output from analog SCART to digital HDMI.
Good luck.
Jan 31, 2009 | Video Game Consoles & Games
Connect ps3 with lcd via HDMI
I have no knowledge of game consoles whatsoever I suggest submitting your request to another expert as we have many here that are experts with game consoles. Sorry I couldnt help you out.
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
82 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
