Question about Samsung TV Remote Control
My Direct TV Remote volume control is not working like it had on my older Sony TV. Just installed new Samsung 7100 and the Direct TV Remote performs most, but not all functions, like volume control. How do I get my remote to handle all functions?
SOURCE: direct tv remote control - tv volume
I have the same problem!
Posted on Jan 25, 2008
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
SpotBert
  • 231 Answers
SOURCE: RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
Posted on Dec 31, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
I have direct tv and want the remote to work
0568,0193,0182,0162,0155 are the codes to check. If you wish to get more setup codes, check this link. Setup code list to DirectTV remote control are given. Pull up older posts.
Mar 04, 2013 | Samsung AH5900092W Remote Control
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Directv remote increases volume slowly
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Feb 13, 2009 | Samsung TV Remote Control
Direct tv remote- volume control
You are wanting to make a digital volume control function like an analog one. Can't be done.
Apr 25, 2017 | Universal Remote Control DIRECTV Universal...
Direct tv remote control - tv volume
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Samsung TV Remote Control Logo
1,012 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
