Question about GE Profile JTP18 Electric Single Oven
I have a GE profile single wall oven and after self cleaning the F7 code appeared. I turned power off and disconnected the ribbon cable, then turned power on and after a few minutes the error code F0 appeared. what does this mean and is there a fix or do I need to replace parts?
  • wcoyle17 Dec 29, 2010
    Is bad clock fixed with new controller
  • 1,531 Answers
F0 code means that there is a thermistor control failure,Recommend you replace the electronic range control.The part number should be wb27k5172.but need full model number to confirm.
The F7 code is A=function pad button jammed or B-Bad clock.try to unstick the button or again replace the electronic control.
Posted on Dec 29, 2010
  • seth adams Dec 29, 2010
    yes it does mean the same thing
2 Suggested Answers
SOURCE: GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Posted on Jan 22, 2009
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
F7 code disconnected power with no luck
F7 stuck keypad
Aug 21, 2009 | GE JRS04 Electric Single Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
GE profile light comes on by itself and then get f7
http://www.repairclinic.com/0078.asp#GE5, this site will give you the code and if your mechanically inclined you can do it your self ,but if the warranty isnt exspensive you might want that,but it is the keypad
Jul 07, 2008 | GE Profile JT912 Electric Single Oven
F7 error code
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel. If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine. If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges. If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections. If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel. Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results. Contact me at hutchipop@yahoo.com. Regards, Charlie
May 08, 2007 | GE Profile JT910SASS Electric Single Oven
F7 code
GE, F7 is a stuck or shorted keypad. You can unplug the keypad ribbon cable from the main board and try to clean the ends with an eraser. See if the code comes back. Catriver...post back.
Sep 26, 2006 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
159 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
