When setting up Timer recordings via the "Guide" (many over Christmas and NOT overlapping) some record OK and others do not - the timed programme seems to start and continues for about 4 hours, way beyond the set recording time , but nothing is recorded - any ideas?
  • 16 more comments
  • R E Jan 07, 2011
    This is the second Toshiba unit I have had. The first one was returned with exactly the same problems. ie - Timer overrunning and no recording, on an intermittent basis - I believe the recording may be OK if the TV is left on standby, but surely this should not be necessary as witnessed by the fact that sometimes the recording is OK with the TV switched off. Also if there is a short in the timer unit , why would this be cured by a new remote?
  • R E Jan 11, 2011
    May have solved the problem by leaving the TV on standby all the time - Would'nt have thought that it should be necessary to have the TV on (standby)though
  • Anonymous Mar 11, 2014
    Instruction manual
    please could you help me I need to return a Vax u90-ma-r air reach upright vacuum cleaner .The motor is not working and I need to send it back as it is only a year old and there is a 6 year guarantee with it thank you
    location knock sensor 2003 chevy truck 5.3
    When the key is in the accessory position lights flash, rad fan comes on and when fully turned on you hear a fast clicking sound
    Hi, I was trying to do system recovery on my old Compaq Presario SR1850NX . I run the two system recovery CDs that I ordered from HP years ago, but the process is not completed and it is asking me for a 3rd CD/DVD which I never had. I only got 2 CD/DVD for the Windows XP Media Center Edition 2005 System Recovery
    F18 comes up on washing machine
    seat belt stuck on drivers side of a 1999 cadillac seville sls
    paper jam on the second page of every print job
    freezer won't work
    I flushed and replaced the power steering pump in my 2001 vw passat but it's still making noise when turning the wheel. I noticed bubbling of the steering fluid and its kinda hard to turn the wheel as well. Help....PLS
    1992 ford tarus replace brake booter
    firing order diagram on 02 2.2 s10
    my 91 ford probe lx is lock in first gear and it want change gear
    drivers door want operate. push button hear motor noise no response, window can manually
    push up and down.
    Front load won't fill
  • Anonymous Mar 12, 2014
    nordic track gx 2.5 will not run a preprogramed workout resets itself after one minute
  • 10,865 Answers
Hello frary..... You may have a short inside the timer causing this problem. Call the service provider and report the problem. Generally they will just provide a new remote since you are a valued customer. Joe
Thanks for choosing Fixya!
Posted on Jan 05, 2011
  • Joe Hogan Jan 08, 2011
    any luck yet?
  • Joe Hogan Jan 11, 2011
    how did you make out?
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
Sep 04, 2014 | Televison & Video
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
My Dish DVR 625 does the "program guide download"
Hello! Dan Busa with Dish Networks customer service department. This sounds like it may be a signal issue, I would make sure the cabling is tight and in good condition. You also want to enable your inactivity standby having it disabled will only make this worse. If everything seems ok you may need a technician.
Dec 16, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I set the self timer on my cannon a560 camera?
Press the self-timer button to cycle through self-timer settings. The rectangle indicates normal shooting, the clock indicates self-timer. Depending on the shooting mode, you may also see overlapped rectangles for continuous shooting.
To change the delay time, select [Self-timer] from the Recording menu.
The self-timer button is the same as the down-arrow on the circular multi-selector, marked with a clock.
Jul 20, 2010 | Canon PowerShot A560 Digital Camera
SONY DVD RECORDER PROBLEMS
if it is only some programs, verify that your recording times are not overlapping and you are setting the timer for the correct times
Mar 17, 2010 | Sony RDR-VX560 DVD Recorder/VCR
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
