Question about LG LRE30755ST Kitchen Range
I get a F-3 open over sensor how do i fix it
  • 1 more comment
  • martinferran Dec 29, 2010
    I HAVE TRYED THAT I NEED TO KNOW WHAT THE OVER SENSOR PART NUMBER IS AND WHERE I CAN BUY IT I HAVE FIX RANGE BEORE AND HOW TO PUT IT IN FROM WHAT I SEE IT JUST A REPLACE OF A PART IN THE OVER WHICH I CAN FIX
    whate you told me was in my book i did not need to pay you for that ans
  • martinferran Dec 30, 2010
    i went to link and they have two part numbers one is item 1351398 and 1351389 which part is the right one
  • 2,382 Answers
Hi, F-3 tells you that the electronic control has detected the fault condition.
Press CLEAR/OFF to clear the display and stop any beeping. Then go to the house breaker box and try turning the house breaker to the oven off for 5 minutes. Electric ovens have two switches in the house breaker box. This will reset the system and clear any electronic glitches that are in the system.
If this does not remedy the situation then this means you have a bad oven sensor.
Unfortunately this is not a home handy person fix.
You require a tech to fix it...
Posted on Dec 29, 2010
  • Tunde Autos
    Tunde Autos Dec 29, 2010
    Hi, you can get the sensor on this LINK......
    The sensor is mounted to the back wall inside the oven cavity and looks like a metal rod about 3-6 inches long and 1/4 inch thick. Replacing the sensor is easy. Two screws hold it to the back wall and there is a quick disconnect harness plug on the other side. Make sure not to lose the other end of the harness behind the wall. Another possible cause is the oven control board - a simple but somewhat more expensive repair
  • Tunde Autos
    Tunde Autos Dec 30, 2010
    Hi, it should be 1351398, but try and remove the bad one from the oven to confirm first before ordering for it...
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
How do I fix this code P0123 for a Mazda Protege 2002?
Probable Cause:-
Possible Causes Setting Conditions
  • TP sensor connector is damaged (check pins for damage, and for moisture)
  • TP sensor signal circuit is open or shorted to voltage
  • TP sensor ground circuit is open
  • TP sensor has failed
  • TP sensor not mounted properly to the throttle body
  • PCM has failed
Engine running; and the PCM detected the TP sensor indicated more than 4.60v (i.e., a throttle opening of 92.27%). Note: This trouble code may set due to an intermittent fault.
Mar 23, 2015 | 2002 Mazda Protege
PO017 code on a dodge journey 2009
P0017 Dodge - Crankshaft-Camshaft Timing Misalignment Bank 1 Sensor 2Possible causes - Engine oil dirty
- Incorrect engine viscosity
- Crankshaft position sensor circuit is open or shorted
- Camshaft position sensor circuit is open or shorted
- Faulty crankshaft position sensor
- Faulty camshaft position sensor
- Timing gear misalign
Nov 13, 2013 | 2010 Dodge Journey SE
I recently bought a 2005 Dodge Neon, the oil light was coming on so I reported to dealer who replaced oil sensor switch, now the check engine light is on so I bought a pocket scanner and it comes up with...
Trouble Code: P0340
No Camshaft Position Sensor Circuit Failure
Possible Causes:
CMP Sensor connector is damaged, open or it is shorted.CMP Sensor signal circuit is open or shorted to ground or to battery voltage or 5v supply circuit.CMP Sensor 5v supply circuit is open or shorted to ground or to battery voltage.CMP Sensor ground circuit is open.CMP Sensor is damaged or has failed.CKP Sensor is damaged or has failed.PCM has failed.I would make a copy of this and tell him that the camshaft needs to be replace or what ever is causing problem,they probaly know.
Jan 13, 2013 | 2005 Dodge Neon
How to fix code p0452 on 2005 Explorer
Trouble Code: P0452
FTP Sensor Circuit Low Input
Possible Causes:
FTP sensor signal circuit is open or the ground circuit is open.FTP sensor signal circuit is shorted to VREF (5v).FTP sensor is damaged or the PCM has failed.Now you have to figure out what FTP is.Trouble Code: P0453
FTP Sensor Circuit High Input
Possible Causes:
FTP sensor signal circuit is open or the ground circuit is openFTP sensor signal circuit is shorted to VREF (5v)FTP sensor is damaged or the PCM has failed.Here's a link.
Jan 01, 2013 | Ford Explorer Cars & Trucks
On a Canon 2318l, what does error **E000007-0000 indicate?
E007-0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Jul 04, 2012 | Canon Office Equipment & Supplies
How do you fix a PO113 & PO123 code on a 02 Jeep Grand Charokee Larado 4.0
Trouble Code: P0113
IAT Sensor Circuit High Input
Possible Causes:
IAT Sensor signal circuit shorted to VREF (5v) IAT Sensor signal circuit is open, or the ground circuit is open
Trouble Code: P0123
TP Sensor/APPS Circuit High Input
Possible Causes:
Related TP Sensor engine DTCs present Intermittent wiring or connector problem TP signal circuit is open or is shorted to battery voltage or to 5v supply circuit TP sensor has failed TP sensor ground circuit is open PCM has failed IAT Sensor is damaged or it has failed (an internal open circuit) PCM has failed
Jun 02, 2012 | 2002 Jeep Grand Cherokee
O2 SENSOR
The codes were cleared after the fix? If they were, then the light means it likely wasn't the sensor itself, but a short or open in the heater circuit to it, or the connector to the sensor is bad and needs repair.
The sensor in question is the Heated Oxygen Sensor (2), located rear of catalytic converter. That is the one you changed, right? Because your car has two O2 sensors, one nearer engine in the exhaust, and this one in back of the catalytic converter. Since you already changed the sensor, here are the remaining fixes for that code: heater power or ground circuit open or shorted, or 2) sensor's connector is bad (maybe damaged from oil contamination).
If car runs good now even with light on, then it's not a huge issue. Driveability won't be affected by that code-just the nuisance of the light staying on. Might just check the sensor's connector. Pull it apart, maybe you'll see the problem. If not the connector, a mechanioc will have to trace the circuit to find the short or open. It's (again) the heater circuit to sensor. Good luck.
Nov 27, 2011 | 1997 Nissan Pathfinder
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
Feb 14, 2010 | Nissan Frontier Cars & Trucks
LG LRE30755ST Kitchen Range Logo
73 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
