Question about Dell Computers & Internet
Whenever i try to install my sound card driver, it would tell me driver not found reboot your system and run this set up again, so i don't know what to do next can i get some help from you.
I have recently replaced xp on my desktop pc for vista , and now the sound does not work, it keeps saying there is no audio output device installed or audio controller, i have been on device manager a
1. no audio device, if you sound card is integrated , first to CMOS inside look at sound card was disabled or not, then again consider driven of problem,
in device management Manager in look at is has yellow of question mark or is laments,, some words on double-click the device (into driven CD), click Update driven program, by prompted update can (don't said you does not yo).
also directly can be placed in the driver CD to install the driver, after installing your reboot should resolve the issue.
2, and if sound card is independent, first look card gold finger whether oxidation, as found gold finger gloss Dim found block rubber wipe to oxidation layer, again see PCI slot within whether has product dust, if has words with rubber blowing blowing clean dust, again with new of Yuan folding up to slot inside wipe about, then will sound card insert PCI slot within, must to plug tight, also no on for a slot try try. Determine Board connection when there is no problem, follow the steps to install drivers, in case of hardware damage alone will solve the problem.
Sep 04, 2012 | Microsoft Windows Vista Home Premium with...
Motherboard Sound card problems k8v-mx
I've produced the link for the download, but firstly remove the audio driver and reboot before trying to reinstall the drivers. Make sure you have very little applications running in the background before trying this.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8V-MX
Jul 05, 2009 | Computers & Internet
Stupidity!
try to take out the sound card again and reboot with card out then install again reboot again and see if that helps and do you know what code 10 error is if not try to find out then you might get an idea of what it is
Apr 18, 2009 | Computers & Internet
About sound driver
Try www.hp.com
To download latest drivers.
Jan 27, 2009 | Edirol UA-4FX External Sound System
Audio Problem
Hi, In my experience as a Tech Support Agent, I've come to see several issues like this, when the best solution will be to do a clean reinstallation of windows, you should be able to do so with the Operating System Disks that came with your computer, as Dell provides to its customers, if you don't have them, you can easily contact them via Chat, at support.dell.com and ask for a copy, this should resolve your issue, be sure to back up your information.
Jan 23, 2009 | Dell Inspiron 1501 Notebook
Window xp display
This should be your graphics card driver is not it. The original installation of hardware drivers may be better.
If that is not what system you set up the software in question. Can be re-systems.
http://www.notebooks-driver.com
Nov 03, 2008 | Computers & Internet
On having to reload windows xp pro I found that I no longer had a working sound device. Is there a connection, should I try again or would this be caused be something else.
hello,
Maybe some make that caused, on destop of the "my computer" right click "properties" and then "hardware" tab and then" device manager"
see pic below:
tell me about error on your system.
melnavz
Apr 15, 2008 | Computers & Internet
Motherborad drivers
Assuming you are running XP.
If it hasn't installed the device ,
uninstall device and reboot then restart
device should autofind and self install
dont forget to reboot to save settings,
Do SP2 Updates and reboot,
Let me know how it goes thanks
Please rate me ,,,Cheers
Sep 22, 2007 | Acer AOpen AW 230 Sound Card
Computers & Internet Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
