Question about Toshiba Satellite A135-S2276 Notebook
Power Cord Falls Out of Socket in Laptop
I've had my laptop for about 9 or 10 months, but in the past week or so, the cord that supplies the power has been jiggling in its socket. Sometimes it doesn't do anything, sometimes I have to unplug it from the laptop and then re-plug it.
Just now, however, no matter how much I jiggle the cord, it will only stay in place for about a second. I have to keep it in place with my hands -- I've tried resting it on something, but it doesn't work. Is there something I can do (I'll settle for tape, if it works!) that will give me all the power I need? Right now I'm relying on battery power, so please hurry!
  • graykitty101 Jul 07, 2008
    Approximately how much will a new DC jack cost? And do I look on the adapter to find the specific model?
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
The part itself (the power pin) is not that expensive ($5-10), it's the labor to replace it that can cause heartburn ($100 - 250). If you are comfortable working on electronic items it's worth a try. I've fixed two laptops successfully. If you can't get it fixed get a JerkStopper to hold the cable in position so it charges. The JerkStopper was designed to keep you from damaging the pin but it also works to hold the cable in a position that will allow the system to charge.
Posted on Aug 26, 2008
    Genius:
  • 2,028 Answers
The DC jack in the machine has come loose or is worn out and needs replaced. Be careful, if the soldier on the jack has broken loose it can cause an electrical arch and do sever damage to the machine.
Posted on Jul 07, 2008
ASUS P5RD1-V MOTHERBOARD BOOT PROBLEM
It sounds like you have a dead battery on your motherboard.  Just replace it and your settings will remain.
Nov 14, 2009 | ASUS P5RD1-V Motherboard
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
Issue with Power Cord...and maybe more?
Check the power rating on the new power cord and compare with the former.
Cheers
Jul 06, 2009 | Computers & Internet
Acer Aspire won't start
There is one common flaw with most all laptops. The socket plug for the power cord is connected to the motherboard. When you plug the power cord into this socket it applies pressure or weight on the socket inside the computer. It sounds as if your charge cord is working. Moving the computer around while it is plugged in can cause even more stress on the plug socket.
Try this...but be careful...using a small item such as a toothpick or other non-metalic item...push up and down on the plug socket. If it moves around this is not normal and probably the cause of your problem.
I fixed my laptop by soldering the contacts of the socket back down to the board. I don't suggest doing this yourself unless you know how to take a laptop apart. Check with your local computer repair shop and have them give you an estimate to either fix by reconnecting or replacing the motherboard. Hope this helps. Thanks!
Jun 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Kensington 33403 power adapter beeping and providing no power
I have the same model. I pinched the cord from the from the supply to the notebook. The cord looked ok from the outside, but was damaged internally. I called Kensington support and they sent out a referb unit at no cost using only the serial number to validate the date of manufacture. The company has a two year replacement policy from purchase date, but if you lose your receipt they came go by maufacture date. give them a call.
HAL
Feb 21, 2009 | ACCO Brands Kensington Wall/Auto/Air...
Power connection broken
Sounds like the DC jack on the motherboard is broken. The jack is very inexpensive, but difficult to replace as it's surface mount soldered to the board and the laptop will have to be disassembled or the plastic case cut/modified to replace the DC jack.
Feb 09, 2009 | Lenovo 3000 N100 Notebook
Power plug on laptop
The power socket may have dry solder on its joints, If you are not a technician, get this fixed by the service centre.
Aug 05, 2008 | Computers & Internet
Power cord adapter falls out of socket in rear of laptop for satellite P105-9722 is there a cure or should i buy a new power cord and adapter?
hi im wesley. please make sure the socket is not maybe broken, if its fine then i would suggest replacing the adapter only because the power cord shuold be fine.
Jul 20, 2008 | Toshiba Computers & Internet
Jack is loose where charger plugs in
This same thing is happening with my acer laptop. I sent it to the company about 3 months ago, and it happened again. I really need my laptop and cant take a month without it. I advise sending it in to be fixed to your laptop company.
Good luck (:
Jun 29, 2008 | Gateway (1532852) Power Supply
Why, AGAIN & AGAIN & AGAIN
No power at all, not even for a second. this happens all the time, it usually comes back days or weeks later, it has been over a week now and nothing. I have replaced the power cord in the past when this happened, when the computer starts up again the older power cord will work again??
Thank you for your quick response.
pl
May 27, 2008 | Acer TravelMate 2300 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
502 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
