Question about HP PL4245N 42 in. HD-Ready Plasma Television
HP MD5880n TV Screen flashing
TV screen starts flashing when on for over an hour and must shut down to get rid of it. Even after the TV is off, still has flashing. TV is only 2 years old and our local repair person is baffled. Help!
  • williamng Dec 31, 2008
    did you able to fix it?
  • HP Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
My tv screen is upside down and cant fix it
I have seen this when on tv you do not use just the exact part for replacement. On computer, you might want to google this since I am sure you are not the only person to have experienced this.
Enter this in google and you will get your answer
upside down screen on laptop
Sep 19, 2017 | Computers & Internet
Hp tv screen flickering
SolutionUse the following steps to resolve the issue.
  1. On the remote control, press Settings , go to Picture , Advanced picture , Auto-sync , and then press OK .
  2. Press Settings , go to Picture , Advanced picture , and then adjust Frequency or Tracking .
May 20, 2012 | HP Md5880n 58 in. HDTV
My HP 5880n TV has started showing purple lines everywhere. Particularly in images that should be shiny. Images of water are the worse and look almost all purple as each shiny part is surrounded by a thin...
I got some water between the 2 screens at the bottom of my HP 5880n. I took the screen out and separated the 2 screens at the bottom and wiped and let dry. I put it back together after it dried and put back in tv, now when it1s on it has a foot and a half circle that is clear as a bell and the rest looks blurred. is there a fix for it or do i have to replace. Where can I find a replacement, I looked on line and can not find any. Thx
Aug 18, 2010 | HP Md5880n 58 in. HDTV
Compaq Presario Laptop half screen issue
no photos of the screen presented.
so all i can do is guess what it looks like,
its so old HP has no info on it. legacy PC, called retired.
i guess 10 years old
2007
so one side is dead, black screen right?
and if you shine flash light on the black side, is there data there or not?????????????????
the v3000 is a CCLF back lamps (edge)
and last 20,000 hours max, (very very short life)
so when one side fails. it goes black
the bulb does or its inverter, supply does.
all do this everyone,
all go dim
then blink
then die, or are random starting.
just like a florecent light in say your garage, same deal. same gas tube.
use the flash light, see its not really BLANK IS IT
only the black lamp quit.
endless post here on topic,
in the year 2010 most of these ended and are now all LED
ending all this pain.
Sep 20, 2017 | HP 435768-001 - Compaq Presario C300...
Picture shuts off
It seems as though the bulb(s) in your unit are about to go out. This is repairable/replaceable by calling your manufacturer. If you are still under warranty they can help you by possibly troubleshooting/replacement/referrals.
Aug 06, 2009 | HP Md5880n 58 in. HDTV
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
TV shuts down
Stating the obvious, I suppose, but it may be possible that the TV is simply overheating. These giant TVs create a LOT of heat. Perhaps removing it from your current TV cabinet and setting it on a stand outside will help. You may even want to try a small fan to blow air to the back of the machine to see if this fixes the issue.
If so, and it's under warranty, I'd have a tech look at it. May be replacement parts that won't run as hot.
Dec 10, 2007 | HP Md5880n 58 in. HDTV
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Screen flashing
you need the voltage on the ps board and the ysustain board adjusted. Possibly the z sustain board needs replaced if this doesn't fix.
Aug 18, 2007 | HP PL4245N 42 in. HD-Ready Plasma...
HP PL4245N 42 in. HD-Ready Plasma Television Logo
418 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
