Question about Danby DWC612BLP Wine Cooler
Hi I have a dwc 612blp cooler that is staying at
Hi I have a dwc 612blp cooler that is staying at 64 degrees F. Whenit started running again, I heard a what sounded like a relay cycling - any ideas? Thanks
  • htbrill Jan 02, 2011
    Thanks, that was what i figured as well, I just thought that i'd turn to the pro's before ordering the parts. Would you suggest changing the Capacitor as well as the relay?
  • htbrill Jan 03, 2011
    i've ordered the relay, i'll let you know how it works out, thanks
  • 8,197 Answers
No do not change the Capacitor just change the relay
Posted on Jan 02, 2011
  • Jyackle5
    Jyackle5 Jan 03, 2011
    Ok sounds good.
    President:
  • 2,468 Answers
The ptc relay and overload on the compressor is bad,it merely unplugs off the compressor and a new plugs in,that is your clicking noise,its there to help start the compressor
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
Engine runs hot and stays hot 4 hours after.
HI Jerry, and the usual suspects are:
1. Insufficient oil supply or oil not circulating.
2. Leaking valves.
3. Heavy carbon deposit in combustion chamber.
4. Ignition timing retarded.
5. Normal engine oil tempurature 180-220 degrees.
6. No oil cooler.
Good luck
Aug 06, 2013 | 2009 Harley Davidson FLHRC Road King...
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
check compressor relay..
also ok so check condenser coil heat no heat so check gas lickeg on capilary tube or" condenser lickeg or" jam capilary tube.
May 30, 2012 | Danby DWC044BLP Wine Cooler
Unit does not get cool. I can hear the compressor kick on, but it goes off about 15 seconds later. After a minute or so it goes on again only to shut off again
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC612BLP Wine Cooler Logo
185 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
