Question about Dishwashers
My bosch shu9925uc dishwaher will not fill with water and start a cycle.
  • slurp222 Dec 29, 2010
    Where is this valve and the pump motor? Is the a schematic available for download?
  • 4,323 Answers
Hi
After reading your post I don't think it is the control that is bad. If you have already checked the water inlet valve and cleaned the water lines & the valve for any clogs then it is the float switch that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
Water enters dishwasher,the unit seems to go on hold, then it will drain. Nothing else works as far as the washing cycle or any thing else.
this could be that the main pump id defective, once water enters the main pump does all the work to throw the water around and clean, once that is done the water is drained etc.
so when you dont hear anything this indicates that the main pump is not running.
supect this part first.
I hope this was useful
Mar 14, 2011 | Bosch SHU9925UC Built-in Dishwasher
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
After cycle standing water remains in the dishwaher
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Bosch Evolution 300 SHE42L1 Built-in...
My dish washer won't stop trying to drain
my dishwasher would fill up and start draining when washing watt should i do
Nov 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
My SHU9925UC/14 will not drain and leaks hot water from underneith.
Aug 30, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch shu9925
take bottom front panel off to expose the bottom tray. you will find there is water in it. mop water out and appliance will operate ok. turn off at mains first.
if fault reoccurs, you have a leak which will have to be traced
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
