Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Spinscrub F 7412-900 brushes wont turn - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
5 Suggested Answers
keemo68
  • 1263 Answers
SOURCE: Brushes won't turn on a Hoover F7426-900
there should be a rubber belt that drives the brushes on either side. hope this helps. please rate this.........thanks
Posted on Aug 30, 2008
  • 3600 Answers
SOURCE: Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Posted on Jun 18, 2009
  • 190 Answers
SOURCE: I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Posted on Oct 05, 2009
VacuumRepair
  • 438 Answers
SOURCE: Hoover SpinScrub brushes not turning
Hi There,
Here's a very helpful Tip that I've written that explains step by step how to diagnosis the Hoover SteamVac when the brushes stop spinning. This will also walk you through how to replace the brush gear turbine assembly if you find that this is the part that is broken.
If this was able to answer you question, and help you fix this, please be so kind and rate the repair helpful, or leave feedback. This is really what keeps Fixya experts continue to answer free repair solutions rather then just the premium ones that customers pay to have answered. Thanks for showing your appreciation.
Feel free to add a comment if you have any questions or need further help.
Here's the link:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 28, 2010
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
Brush wont spin
Check the filter on the front of the machine lower left. The brush is powered by the exhaust of the suction motor with a small turbine.
This filter reduces the air flow and can cause the machine to not turn the brush.
Jan 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Ths spin scrub brushes wont spin
Be sure the speed switch is set to carpet. Also remember the brushes won't turn until the handle is tipped back. If this is not the problem, remove the brush and insert a flat screwdriver into the square hole the brush pin goes into, and be sure it turns ( there will be some resistance ). If it is seized up, the turbine will need replacement. There is also an air intake screen which must be kept clean. It is located behind a clear plastic cap on the upper front of the floor nozzle, just above the brush "spinner".
Feb 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Sep 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
The spin brush wont spin but the water is spraying out and sucking up
possibly the brushes need cleaning http://www.hoover.com/pdfs/manuals/F5914900.pdf manual for your steamvac
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover brushes wont turn
Is the shaft on the brush block or did it break off, if it did, replace the brush block. On the top, left rear corner is a lever that moves baack or forward depending on the handle being upright or tilted back for usuage. Is it moving? If not then you have a problem there. Otherwise if the square hole doesn't move when it is turned on, and the lever is switch to the on position, then replace the turbine.
Jul 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
165 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
