Question about Toshiba Portege R100 Notebook
Just installed windows 7 on my toshiba portege r100. the built in SD card reader does not work. is there a compible driver that i can use?
SOURCE: toshiba portege R100 bloqu? sur password
Hello:
i have problem portege ,when i do on it, always password show,but i have not not any
before password, any one knows how reset the bios ,
my e-mail: selectpro@hotmail.fr
Posted on May 23, 2008
kbdesign
  • 370 Answers
SOURCE: toshiba portege r100
Now, that is a tough one. Only way to unlock the hard drive is to have the original password. You will not even be able to access it retrieve any data you want to save.
Thinking you are in the market for a new hard drive and a complete reload of the system.
Posted on Mar 16, 2009
gurutim
  • 68 Answers
SOURCE: how to reset the power on password toshiba portege r100
Go to: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=108503&ref=EV
Drill down to your password reset scenario. This is for all Toshiba laptops.
If this helps you, and you wouldn't mind, please take the time to rate my response to you.
Much appreciated...
gurutim
Posted on Mar 22, 2009
SOURCE: on my toshiba R100 / SD card reader doesn't work
this problem bugged me for weeks!! finally figured it out today
download the sd card reader drivers from toshiba (not a 3rd party site) boot into safe mode delete all the sd card reader drivers currently installed install the downloaded driver reboot into normal mode
let the computer go about its business installing the driver, then it should work.
cheers, thomas..
Posted on Apr 21, 2009
  • 413 Answers
SOURCE: built-in SD card reader (ASUS Eee PC 4Gb) is not working!
Try here> http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Jun 06, 2009
Toshiba Satelite SD Card reader driver
It's a common problem when you do a OS upgrade, Is that the only device in Device Manager that isn't working? Any Unknown Devices? You didn't supply the Model of Toshiba, or the original OS? Download and save the Card Reader driver for Win 7, Change the Compatibility of the driver and install.
Feb 03, 2013 | Toshiba Satellite Computers & Internet
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
How i format my toshiba r100 harddisk completely.
when you start the computer up with the install disk of your windows there is an option to format the drive. Your other options are more technical (boot disks etc).
Oct 11, 2010 | Toshiba Portege R100 Tablet PC
How do i reformat my portege R100?
In order to format the laptop, you will need a bootable windows dis. Start the Laptop with the bootable disc and when it asks where do you want to install the windows, select your hard disk and select the option to Format i t from there.
Nov 24, 2009 | Toshiba Portege R100 Notebook
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
It is possible to remove the domain login and networking setup, but you need to remove programs and cleanup/remove some registry items.
The best way to fix your problem is to wipe the hard disk and install Windows again. The Windows licence label is on the bottom of the laptop, use this product code to install Windows, you can borrow a Windows CD to do the install. Don't forget to download the device drivers from the Toshiba WEB site before you format your hard disk. You need to install your programs again as well.
If this is too hard then the easiest option is to put up with the login problem.
Jan 17, 2009 | Computers & Internet
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
On my toshiba R100 / SD card reader doesn't work
cheers, thomas..
Sep 28, 2008 | Toshiba Portege R100 Notebook
Toshiba Portege R100 Notebook Logo
537 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
