Question about Abit KN9 Motherboard
I would like to know where i can plug in a new sound card, as the one which is built in has broken.
  • 571 Answers
On the PCI socket on the photo in yellow on other motherboard are white.
Posted on Dec 29, 2010
I bought an Hp m9152p with a vista 64bit os about 2 years ago, and the sound card just stopped working a couple days ago. There is no response when I plug in any audio device(speakers or headphones) in the...
if it is built into the motherboard you cannot change it wthout changing the motherboard.
I assume you are using Windows (prob Vista on machine age)
go to the control panel - sounds and run the test - sometimes that fixes sound issues
if not uninstall the driver and let windows find the hardware and re-install it.
Let me know if you are still having problems.
Dec 17, 2010 | HP (400745-001) Sound Card
How would i know if i have a sound card
There are 3 possible scenarios:
  1. You have an "external" sound card
  2. You have a "built-in" sound card
  3. You have no sound card
External sound cards are separate extension cards that is plugged into the CPU to give it additional functionality like giving a high definition sound through high specs sound cards. It looks like below:
And when inserted in the CPU, it gives you an extended sound port at the back like below:
While built-in sound cards are those that are already provided by the motherboard that your computer has. The provide the same sound ports especially the color for the ports since these are industry standards.
Please take a look at the rear part of your computer. If there is, then you've got a sound card plugged in. Now make sure the necessary software is installed.
  1. Right click "My Computer" and click "Properties"
  2. Click the Hardware tab and click the "Device Manager" button. Locate the "Sound ... group and you should see if there are red "x" or yellow question marks "?" there. If there are, you need to install the software for your sound card.
Feb 13, 2010 | E-Machines eMachines Desktop PC
How to replace a broken soundcard on a Acer Extensa Laptop
Most sound cards are intergrated into the motherboard, you can't just replace it, you can look to see if the weld is broken and try to repair it or just go get a plug n' play sound card
Jun 25, 2009 | Computers & Internet
Dont know the sound card name and there is no sound what can i do
Do u have built in soundcard or a bought one? If that is built in, just go to the site of maker of the mainboard, search with the model name of the mainboard, you should get the driver. If that is a bought one, Remove the cover of the CPU, look at the soundcard..look for the name of device part number. google with it..you should find the solution.
Apr 03, 2009 | Computers & Internet
My New System with the following Intel Motherboard Realtek High Definition Audio is not working or installing from the Given Cd. Realtek High Definition Audio Driver for Intel Pentium Dual Core E5400
hi im josh in cebu phils. may i help you friend. try to use this solutions surely it will help you. then try to vote me if my stuff works so that i will know if i helped you. so. here: Problem: Your New Sound Card Doesn't Work—You Don't Get Any Sound Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
Okay, now that the easy stuff is out of the way, let's turn to something more difficult. The most likely cause of no sound is some sort of conflict. One by one, change your card's DMA, IRQ, and port settings. (This might entail resetting some jumpers on the card itself, as well as making some software-based changes.)
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work. good luck.
Mar 05, 2009 | Computers & Internet
My sound driver can't install...a built in sound card, my motherboard is emaxx.
hi im josh in cebu phils.may i help you? friend try these solutions i gathered; Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work. thats all for now good luck.
Mar 04, 2009 | Computers & Internet
Compaq CQ50 Laptop
If the sound works on you headphones the either your built-in  speaker(s)  is/are  bad or more likely the headphone jack itself is broken and not making contact in the speaker position which is fairly common.
Feb 28, 2009 | Compaq Audio card Sound Card
No sound when connected on aim
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Dec 01, 2008 | Logitech QuickCam Connect Webcam
X-530 Not working!!
Ensure that your sound card setup/diagnostic software can correctly recognise your speakers. You will need to know what sound card is in your PC. Be carefull with PCs that have sound cards built onto the mother board and that also have a seperate sound card. Ensure the sound card you want is the one you have plugged the speakers into and ensure you have disabled the other sound card and its software.
May 02, 2008 | Logitech X-530 Computer Speakers
Speakers work...just not when plugged into desktop
Hi, what you probably need to look for is driver for your sound card which is built-in into your motherboard. Try to get the model no. of your mb and proceed to their website to download appropriate drivers. Drivers are OS specific. If your sound card in a plug-in PCI card, then you would have to check the chipset number or the sound card model no. to get the right driver. Hope this helps.
Jan 08, 2007 | GE ULTRASONIC PRO 2.0 Computer Speakers
Abit KN9 Motherboard Logo
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
