Question about GE 31GT720 31" TV
Do I need a digtal converter box to pick up local stations via antenna?
    Guru:
  • 374 Answers
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Posted on Dec 29, 2010
How to get analog channels on my Toshiba?
The problem is probably that your antenna can't pick up any of the remaining analog stations in your area. Only low-power stations are still broadcasting an analog signal. If you are using an indoor antenna, you might the signal with an outside antenna with an amplifier. (Check a site like tvfool.com to get the direction to any nearby analog station and make sure that your antenna is oriented correctly. This site or antennaweb.org will also help you orient your antenna for the digital stations in your area.)
You need a set-top digital tuner or a converter box to translate the OTA digital signals (ATSC) and translate them to the analog NTSC format. Low end converter models with only SD output are harder to find but still available. However, there are some converter boxes that have HD output as well. This one, http://www.solidsignal.com/pview.asp?mc=03&p=3500STB&d=iView-HD-DVR-ReceiverConverter-Box-for-TV-Antenna-QAM-(3500STB)&c=Digital%20Converter%20Boxes&sku= , lets you attach an external drive (USB flash drive or hard drive) . It connects via component video or HDMI. (We've had good luck with our model with a portable (2.5") external hard drive. It replaces the SD converter box and DVD recorder.)
I hope this helps.
(In my area, there is only one low-power station still broadcasting. Its transmitter is nearly 40 miles and can only be picked up with the external antenna and amplifier. If the weather is bad, we will lose that signal. Beware: an amplifier can become damaged and block the signal. The usual check for this removing the amplifier and attaching the antenna directly to the TV. For low-power stations, this test doesn't often help.)
Dec 21, 2014 | Toshiba 50H82 50" Rear Projection...
Why can't i pick up channels using a RCA converter box, amplified HDTV antenna on my rca XL 100 analogue TV
If you live a good distance from the TV station you may need a better antenna. Did you do a channel search on the converter box? You'll need the remote for the converter box to change channels, not the TV's remote.
Jul 16, 2014 | RCA Televison & Video
We have a mitsubishi 1080 hd model ws-48311. We no longer have cable do we need a converter box for this tv to pick up free tv. Thank you
No. All you need is an inexpensive antenna to pick up local TV stations. If the stations are close, all you should need is something like this one: http://www.walmart.com/ip/RCA-Digital-Flat-Antenna-made-for-DTV/10542272
Sep 09, 2013 | Televison & Video
Will this tv work with an antenna or does it need a converter box?
All LCD tv's made in the last 10 years support digital tv out of the box and do not need a converter box. However if you want to pick up local stations over the air, you may need an external antenna. Otherwise if you have cable tv or other services, you can connect your service to your tv directly.
You may also want to call your service provider (if applicable) if you have issues connecting it to your tv.
Mar 25, 2011 | Sylvania 6615LE LCD HDTV
Do I need a TV digital to analog converter box to use my outdoor antenna to pick up local stations?
Hi
Possibly but that depends on your antenna. What you will need to do first is change your TV's input selection from cable to ant. Should be in your menu.
Mar 09, 2010 | Hitachi 43UWX10B 43" Rear Projection...
GE Model 20GT360 TV and digital antenna problem
Are you connected to a digtal converter or just a digital antenna? If only to an antenna then yes you will most likely pick up one or two low power UHF stations that are still able to broadcast in analog.
Nov 17, 2009 | Televison & Video
I cannot get a signal with converter box and Philips indoor antenna
Try to manually enter the local DTV Station Channels, instead of letting the converter scan for channels. And try moving the antenna and then re-entering the DTV channel.
You should really have an external antenna that is matched to your local reception needs.
contact your local TV stations, their engineers will be more than happy to help.
Jun 15, 2009 | Durabrand DWT1304 13" TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
118 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
