Question about GE GSH25KGRWW Side by Side Refrigerator
GE model #GSH25KGRB WW: Neither side, freezer or refrigerator, cool. Lowered cooling on both thermostats and Inserted Thermometer in either side and neither lower then 50 degrees F. Fan working in bottom. No smell or stains from refrigarant but one copper line, high side, of compressor has oil residue on it.
4 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
SOURCE: side by side refrigerator problem GSH25KGRB WW
change its hearter mosty goes bad inGE refgrator
Posted on Feb 19, 2009
  • 11 Answers
SOURCE: no ice being made. green light is blinking. what gives?
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
GE Model TPH 21 PRSM WW does not turn offf
Many things that could cause the problem First if you just plugged it or have little in it, it will run for a long time. Next check if if it is cooling properly place a thermometer in a liquid it the refrigerator compartment it should read around 42 degrees. If it is warm in the refrigerator compartment Look at the freezer back wall for frost buildup If you have frost on the back wall, you will need to defrost it and repair the defrost circuit. This is a. Common problem on GE models If the temperature is good in the fresh food compartment you will probably need to replace the thermostat or cold control
Aug 01, 2014 | GE Refrigerators
Freezer woorking ok fridge not cold model GSS20DBPC WW
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2010 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE not working
Change the defrost heater, It's located at the bottom of the frosted coils and should have a pink and blue wire running to it.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25KGRWW Side by Side Refrigerator Logo
160 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
