Question about Biostar M7NCD ULTRA Motherboard
Wont boot, wont even post. - Biostar M7NCD ULTRA Motherboard
Acer am5100-u5300a
This motherboard is strange in that when the CMOS battery dies, it wont POST and wont have video output. Just replace the CMOS battery and it should work again. And also set the new date+time.
Jul 04, 2013 | Computers & Internet
I'm trying to install Vista for a friend of mine on his computer. It uses vista boot loader 2.1.1 (or something similar) The first time it will boot just fine - vista will boot after first start and...
one check the crack make sure it is for what your installing ( i mean ver and sp) if all else fail try a differant crack you know as well as i do they dont all work all the time and check you registry cant tell you here but look in registry file
Sep 24, 2010 | Computers & Internet
Wont go into safe mode or boot from cd menu
F10 is usually the boot sequence key for most laptops. but you posted in the ACER section for a DELL so its a little diicult to decide which information to give you other tha F10
You could always watch the boot sequece as quite often there will be a message there to offer you an option of chanhe boot device or even a recovery option
Aug 17, 2009 | Acer Aspire One PC Notebook
HP Laptop booting issue
Try getting to the BIOS and load defaults.probably an issue with system BIOS also.let us about the result after that
Mar 18, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Master reset of my toshiba satelite
Put in the restore CD and hold down C while booting, this will allow you to boot from thh CD and select how you want to restore the computer. Alternatively, you can attempt to boot in safe mode with command prompt, and type "chkdsk /r" without the quotes, and press enter., post your results.
Jul 17, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Benq joybook 3000 doesn,t go to post
it sounds like the mother board is fried take the ram out one at a time and see if it boots.
May 21, 2008 | BenQ Joybook 3000-01 Notebook
Laptop wont boot
windows cant be bad, seems your laptop is not geting throught POST (power on self test)
I could probably fix or find the reason If I where near you but not much I can say from here.
Id take it to a professional for analysis, simple problem analysis shoudnt cost itself at all. so.
easyer on all of us that way.
Mar 27, 2008 | Dell Inspiron 6000 Notebook
Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
Mar 07, 2008 | Dell Latitude D600 Notebook
Biostar M7NCD ULTRA Motherboard Logo
24 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
