Question about Kodak 6800 Thermal Photo Printer
Paper jam 71
Hello and good morning:
My printer 6800 gave the message "paper jam 71". We have swapped the print position sensor and the engine motor of paper that is beside the power supply. But the message continues. Makes 5 or 6 evidence and then gives the error. I turn off, I would call and make 5 or 6 more evidence. If you answer me, my email is lrsantos@iol.pt
Thank you
    New Friend:
Which is the component on the card to replace if you can show
Posted on Jan 20, 2015
  • 4 Answers
Paper jam 71 is an error that occurs when a driver on the controller board (IC-28) begins to wear out, or the timing gets thrown off. This causes one paper feed motor to drag the other one. This error is normally accompanied by a loud grinding noise because of this. Kodak's newest firmware version is supposed to fix the problem. If that has no effect then the fix is to replaced the controller board.
Good luck.
Posted on Dec 08, 2008
My Printer is Laser, Cannon LBP3000, while printing paper jammed into the roller, computer gave instruction that "open the top cover of the printer and remove the paper by pulling". But after...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Canon LASER SHOT LBP-3000 Printer
Mfc 8420
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 27, 2010 | Brother MFC-440CN InkJet Printer
Says it keeps jamming, but there is no jam. Seems paper feed doesn't work.
Hello there
You may not see a paper jam.
Mar 29, 2010 | HP PSC 2355 All-In-One InkJet Printer
Paper jam error message..no jam
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hello, My Canon Mx300 is not loading papaer correctly. The paper is being pulled in from the right hand side of the loader and causing it to crease and then jam. No settings have been changed. Printed fine...
Hello there
Jan 11, 2010 | Canon MX300 Office All-In-One Printer
Message: Paper jam. But there is no jam. Won't
Hello there Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Paper Jam Message (but no paper jam)
Hello there
Some times you not see the jam.
Nov 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper jam
Hello there
May 15, 2009 | Brother DCP-330C All-In-One InkJet Printer
Kodak 6800 Thermal Photo Printer Logo
661 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
