Question about General Electric GE 24-Hour Timer, 2-Pin #15004
Where can I get the full instructions for GE 15119-1 Timer there was none inside the package? Need to print them out and store them with the device when not in use.. please e-mail me at hitechcomp@sbcglobal.net
Link below has photo of GE 15119 to confirm correct product and also has link to manual
ttp://waterheatertimer.org/GE-timers-and-manuals.html#15119
If this is not your timer, add a comment with description of timer
Posted on Dec 30, 2010
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
Feb 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I've lost the directions for setting the GE Timer Model 15119
You posted under GE 15119 timer.
Open page to identify timer and download manual:
Manual has pictures that clearly illustrate how to set timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Garden
Setting the GE timer 15119
the GE timer 15119 is a push pin design. The easiest way to start is to ensure all pins are up, then push down the pins that represent the time period you want the appliance ON. For example, if you want a lamp on from 7pm to 10pm, push down the pins between the 7 and 10 on the black portion of the dial. then rotate the dial clockwise until the arrow points to the current time of day. Turn switch to the "timer on" position. Plug the timer into the wall outlet, then plug the lamp or appliance cord into the timer and you're done.
Hope this helps.
Dec 29, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set ge timer 15119
Manual for GE 15119 has photos that explain timer operation:
http://waterheatertimer.org/pdf/GE15119-Manual.pdf
The photos along with words in manual explain better than I can repeat here.
You can also pay a fixya expert to answer your question over the phone for a fee.
The expert will walk you through the steps by repeating steps shown in manual.
Dec 19, 2010 | Hardware & Accessories
I have a ge model No. 15119 timer and I don't know how to set it
Open following link to identify timer
Page has manual that comes with pictures and clear instructions
Dec 11, 2010 | Hardware & Accessories
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
Nov 18, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
GE 15119 instructions please. The dial just says "time now." How do you know when light go on and off? Need directions. Can't believe there are none!
Here the help you need to set timer.
Rotate dial until current time lines up with black triangle located in center of dial
The black pointer remains stationary when you rotate outer dial
Now the outer edge of dial has 48 plastic segments that lift up
776e6ad.jpgHere are some segments lifted up on GE15207 timer
As I recall, segments-up timer OFF, segments-down timer ON
If you need more assistance, answer back and I will help
Oct 24, 2010 | Hardware & Accessories
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Dec 08, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
General Electric GE 24-Hour Timer, 2-Pin #15004 Logo
595 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
