Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch WFF2000 Spin problem. During the final rinse the drum stops, a motor can be heard revving up, then a big bang as the drum starts. The machine jumps around for a few seconds then proceeds to the end of the cycle. Spinning and washing is otherwise normal.
  • 57 Answers
SOURCE: Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Posted on Jul 15, 2008
  • 14 Answers
SOURCE: bosch wff2000. goes through program
it sounds very much like the carbon brushes in the drive moter. the best way is to remove the motor and then you can also check the commutator for wear as well. model no and serial no needed to get spares, sometimes moter type.
Posted on Oct 06, 2008
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
VtToolMan
  • 704 Answers
SOURCE: No user's manual for Bosch WFF2000
Donna,
Give this a try! This might be just what you're looking for, but unfortunately, there isn't a model number provided for the download.
http://laundry.manualsonline.com/manuals/mfg/bosch/bosch_washer.html
If that doesn't give you what you're looking for, go to the link below and enter in your information and Bosch will contact you directly and should be able to provide a link for a downloadable (free) manual for your washer.
http://www.bosch-home.com/us/bosch/customer-care/contact-us.html
Another possible source, although I've not used them before is the following link. You'll need to provide your information for them to send you an email, but not sure if the provide free manuals, or charge a small fee for their service. There is no cost to at least enter in the search parameters to find out.
http://www.2instructions.com/search.php?cmarque=BOSCH&modele=WFF2000
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I've a 97 bosch wff2000, washes, drains but will NOT spin either after main wash, rinse nor does it do the final spin. Had it from new, so definately can't complain. I've just replaced brushes...
Try disconnecting the small bore hose from the pressure chamber it could be the switch has stuck in the on position in which case the pressure chamber is blocked (the chamber is at the other end of the small bore hose )
Mar 28, 2017 | Bosch Washing Machines
Washes great once it gets to the final rinse and spin its banging like some thing inside the machine stripped it down nothing in it x
The load of moist clothes inside the drum is out of balance. Open the door on the machine and wait for the drum to stop, then spread the clothes around the drum as much as possible. This should help to rebalance the drum.
Jan 07, 2013 | Washing Machines
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Bosch wff2000. goes through program but drum not turning. creating a sparking sound when spin intermitently works
Oct 05, 2008 | Washing Machines
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
Oct 05, 2007 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
57 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
