Question about Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker
Rising cycle zojirushi bbccv20 I have a zojirushibbccv20, it doesn't seem to be heating properly during rising mode. but baking is fine
  • m3r1 Jul 14, 2008
    We are having the same issue, the heating elements works during the baking cycle, however the bread is not rising. What to do???
Have you 'proofed' your yeast? The rise temperature is not very much above room temp, particularly in the summer months. I would expect the bread to rise at least 3/4 as much without any rise time heating.
Posted on Sep 01, 2008
Does self rising flour need time to rise/
self rising flour uses baking powder as a leveling agent, so it rises as it is being heated in the cooking process, not like a yeast dough.
the following is taken from another site, I could not have said it any better.
Self-rising flour has an almost magical sound to it. And if you look at recipes that call for it, you'll see that they do not call for the addition of salt or leavening agents, though biscuits, cakes and breads made with seem to rise up just fine. The reason for this is that self-rising flour is actually nothing of the sort. It is flour that has a leavening agent - baking powder - and salt added to it during packaging. Since the ingredients are evenly distributed throughout the flour, you will get the same nice lift to your baked goods every time you use it. If you don't have self-rising flour and you have a recipe that calls for it, you can make your own by combining 1 cup all purpose flour with 1 tsp baking powder and 1/4 tsp salt. Similarly, if you only have self-rising flour, you can reduce the baking powder and salt called for in a recipe that uses standard all purpose flour.
Now that being said, it is also worth noting that there are several brands of self-rising flour that have a lower protein content than all purpose flour (11% protein). They are effectively cake flours (8% protein). Wheat protein, or gluten, is what gives baked goods much of their structure, but it can also cause a bread to be too dense or tough. White Lily and Presto are two examples of self-rising brands that use a low-protein cake flour as their base, and if a recipe calls for one of them, you should use cake flour in place of all purpose in the conversion given above.
Jan 03, 2015 | Home
Why does bread deflate?
See if the paddle shaft in the bottom of the pan is frozen. If it is, free it up manually. Then get it good and dry and oil it with cooking oil. After that, every time you bake, put the oil for the recipe in first and turn the paddle until it moves freely. Once the oil is in the bearing, it will keep the water out and the machine will move properly. I have gotten away with this fix for hundreds of loaves.
Jul 09, 2014 | Cuisinart CBK-200 Bread Maker
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
The bread does not rise properly.The model# is BBCC-x20.All instructions are followed and yet the machine does not bake a consistent,even loaf.
Try a different flour. Make sure it is a Strong bread flour suitable for Bread machines. perhaps your packet of yeast is stale.
Dec 02, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Have spectra extra large self clleaning oven never had trouble oven does not work i was baking and it worked fine. Then when I went to bake later and turn the oven on it clicked but never got hot. Yhe...
Hello - Most troubles with ranges occur during the "self-clean" cycle. The problem- no lower burner- could be a bad ignitor. Part is 40-75$ Fairly easy to install, or have done for about 75-100$ Let me know if info helps- I have more if you need it - Thanks- ED
Mar 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Bread machine -- bread falls during final baking
my bread falls as soon as the baking program starts help
Jun 08, 2009 | Kitchen Appliances - Others
Hitachi HB B102 Bread is short and dense
Try 'proofing' your yeast; I've gotten a couple of NON-stale dated envelopes that caused the same problem.
If they are baking through, there isn't likely anything wrong with the bread maker unless the rising temperature is no longer right. During the rest time, feel inside the container to see if the dough is getting enough warmth to rise.
Feb 13, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker Logo
203 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
