I have a Samsung S730 digital camera and like it very much. I have a 1GB SD memory card and it works great, but I want to purchase another memory card, but the only SELL 2GB SD cards is that ok to use in this camera?
I can't find any info on size of memory SD cards in the manual.
Thank you, Beverley Kuter
Re: I have a Samsung S730 digital camera and like it very...
Hi
The Samsung S730 digital camera will work with 2Gb Secure Digital (SD) cards without an issue. If you want to go with a higher capacity card you can also use 4Gb and 8Gb SDHC cards.
Hi, Here is a tip that may help you with your problem....
I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer... The process for your camera may not be exactly the same, but should be similar.
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
Press the Play mode button (the right-pointing triangle) to get into the PLAY mode. Press the MENU button to display the play mode menu. Use up/down to select "COPY TO CARD."
The camera only supports SD memory (limit 2GB), not SDHC (4GB and more). The manual claims up to 1GB guaranteed, though the camera recognizes my 2GB card card.
Usually when you take pictures using NO SD card you can't take the picture, however in this case the pictures you took are stored in a memory bank temp only to test the picture your actually taking. In the manual what's the size of the built in memory card? Usually it's small amount of memory built in
