Question about ASUS EAH5850 DIRECTCU2DI RADEON HD5850 Video Card DDR5 PCIe DVI HDMI Display Port
When i plug in my card and boot my pc, it makes a high pitch squeeling noise and ive added another power cable but it continues to make the noise, how do i remove the noise?
    Problem Solver:
  • 4 Answers
From my experiance it sounds like the power supply is still not providing enough amps for the card or that the power plug on the card may be bad and not allowing it to recieve the power it requires
Posted on Jan 11, 2011
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Amp makes noise
A High pitched noise usually comes off a capacitor before it gives in but often it can continue for a long time before it blows. That sound can drive you crazy I'm sure.
If you do decide to do it yourself with a soldering iron, search for capacitors that are rounded as if they built up some pressure inside them. On the PC board they are usually found together in groups. You can identify the faulty one as it has a rounded top. But if they are not rounded you can power the board up and press in the middle of every one with a non ferrous/conductive object like plastic Nylon or wood (I use a chop stick) You will hear the sound change when you touch or put some pressure on the one making it. It is best to replace the whole group that you find it in when you replace them because usually when you replace the one only, in a short while the others also begin and after all your work to get to if you will loathe having to do it again.
Best to wear safety glasses in case it pops while its open. Its not too bad when it hits you even on your cheek but it may damage your eyes.
A tip that sometimes work as a last resort before replacing them. Make a slight dent in the side of the one making the noise. Technically it cannot be explained why this works but it often does. But only do this when you are ready to cart it off to a radio repairman or replace them yourself as a final shortcut to ensure you have a plan B in place if it fails.
Aug 13, 2012 | Rockford Fosgate - T2500-1bdCP - 2500W...
My 2004 range rover is squeeling when you unlock the doors
Sounds like a solenoid going bad in the power lock control.
May 05, 2012 | Cars & Trucks
Acer aspire x1700 black screen, makes high pitched noise, doesn't respond
You may have damaged or dislodge a component.
I suggest you remove the cover and reseat the RAM modules and all the cards in the expansion slot (unscrew them pull them out of the expansion slots and insert them back then secure them with the screws.
If it still does not boot up then you need to take the computer to a computer repair shop.
Mar 11, 2012 | Acer Computers & Internet
5 yr old Asus with antec 450 power supply has had NO issues ever. Now I need to turn the ps off and on 2 or 3 times before the start switch at the front of the comp will work.... once it boots up...
there are several filter capacitors inside the power supply that are defective and /or are changing value. this accounts for the high pitch squeel you are hearing...the only REAL way to test for these problems are with an esr meter or lcr bridge, but you can physically look at the capacitors and see if any of them are bulged up or leaking., my suggestion is to go to tigerdirect.com and get another 450W or better PS...they are pretty cheap there
Dec 27, 2010 | Antec SP450 450W SmartPower ATX 2.0 20/24...
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitched squeal coming from power supply on my philips VCR
hi , i am a hardware engineer in the uk here to help if i can, the vga, doesnt normaly squeel , i have not heard of this problem , is the graphics card pci or does it go into the brown slot,if its pci the try change the card to a new one if its a brown slot where the card goes it may be the board slots blown as you say the vga only works for a few moments , see if that helps regards steve
Mar 18, 2007 | Philips Refurbished POWER SUPPLY 50/60 HZ...
ASUS EAH5850 DIRECTCU2DI RADEON HD5850 Video Card  DDR5 PCIe DVI HDMI Display Port Logo
132 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
