SOURCE: talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
SOURCE: My Saeco Talea Giro plus
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
SOURCE: our saeco talea giro descaling
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
SOURCE: how do I descale my saeco talea giro plus before
Hello your machine specificlly says in the manual The descaling must be done when indicated by the machine. Click this link this is the manual to your machine
http://www.italianlifestyle.co.za/content/manuals/taleagiro.pdf if you are having an issue with the amount of water coming out of the unit you can use a pin or a needle on the nozzle head page 18 in the manual describes the weekly steps that must be taken to clean the machine as well as the brewer area of the machine. If you have any futher questions message me back Thanks
Rick
