External microphone not working windows xp. I cannot speak with friends on skype.
  • 475 Answers
Check if the mic is being recognized by skype, if you open up the skype options under audio make sure your device is selected in the dropdown. If it is enabled check for sub options.
Posted on Dec 29, 2010
I can hear them on video chat but they cant hear me
make sure have installed the drivers for microphone http://www.driverscape.com/manufacturers/acer/laptops-desktops/aspire-5315/619
Jun 03, 2016 | Acer Aspire 5315 Notebook
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Why can my friends not hear me talking to them on Skype?
On a Mac mini made in 2010 or later, you'll need to use an external microphone to communicate as they're not built in. Plugging in a pair of Apple EarPods or headphones into the headphone jack should work just fine.
USB microphones will also do the trick (but you'll need to adjust some audio settings in Skype).
Hope this helps!
Sep 13, 2014 | Apple Mac mini Desktop Computer (Aluminum...
Windows Vista. Using Skype, the person on the receiving end can't hear me. If I am running iTunes on that computer, though, the recipient can hear the music, just not my voice. I can hear them.
Hi
Start skype. Choose the menu calls then sound settings, select the device through which to speak: web camera, if you are using a built-in microphone or any other bluetooth headset if you are using or external microphone
Oct 03, 2010 | HP Pavilion dv1000 Notebook
I skpe using my Asus, and my microphone does not work.The other party can't me...how do I solve this please
Hi
Are you sure that this laptop has a build in microphone? or are you using a external microphone?
in either case the most likely problem is that the skype sound settings on the input are wrong.
open skype, tools, options, then the audio settings page.
On the microphone, try all the possible options offered and see if it detects your voice, you can also try calling the skype test number / echo123.
When you see the volume bar light up green like this as you speak or tap the microphone its working.
If you are using a external microphone, are you sure you have it on the right slot? Try the other plugs on the laptop and then go over the options again and see if you get sound.
You should also check from volume control that the microphone is not muted.
To check that open up start -> control panel -> sounds -> recording -> select the microphone and click properties -> check the levels tap and make sure its not muted and its turned up to full volume.
also some microphones have a on off switch on the wire, make sure its turned on.
By now you should be able to talk on skype.
Let me know if you need further assistance.
Thanks,
Ekse
Aug 13, 2009 | ASUS m6n Notebook
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
No Picture on my Webcam. Microphone works fine. Drivers installed
you'll need to select the camera you're using in order for both video and audio will work together.
Dec 23, 2008 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
I cant get my built in mic to work for my acer travelmate 2313LCi..?
I'm assuming your speakers work and you're running Windows XP. Please correct me if otherwise.
There are two settings for the microphone in Windows XP. One is for the volume of the mic you hear through the speakers. The other is for the recording volume of the microphone (and the volume others here when you speak to them through Skype or another program).
First check the recording volume:
Volume Manager (double click on speaker icon on your taskbar) -> Options -> Properties -> Recording -> OK -> Make sure the Microphone slider is at least halfway turned up and make sure the Microphone is selected
Next check the playback volume:
Volume Manager -> Options -> Properties -> Playback -> OK -> Make sure the Microphone isn't muted and adjust the volume according to your preferences
May 31, 2008 | Computers & Internet
Sound
Go to control panel > speech and audio devices > select audio > select recording > select advanced > Select Microphone (make a tick mark) adjust the volume just above middle level. and close it. OK. Now the problem should be solved ! Note: If your skype supports audio configuration run that . Also remember to use two channel audio if your system supports 6-channel audio onboard.
Oct 02, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
