Question about Sony MHC-991AV Shelf System
I have a sony 991av stereo I put a cd in it and it reads for a minute and says no disk, I don't no what's wrong
3 Suggested Answers
  • 133 Answers
SOURCE: My sony MHC-GX99 stereo will not play my cds.
Some possible causes:
a) dusty laser lens - cleaning it is the solution, you may use the lens cleaner disc (the one that uses liquid), this can be purchased in many shops. I prefer to clean the lens manually, using a cotton stick and some ethyl or isopropyl alcohol (DO NOT use acetone, benzene or similar strong solvents, these will ruin the lens).
b) dirty brush contacts inside the spindle motor (i repaired quite some CD players that had this kind of trouble). They cause the motor to spin with less power so the driver tries to compensate putting more power into the motor, which causes a feedback effect on focus (it may not work properly). The best solution for this is to replace the spindle motor (if you can find one), the second best solution is to clean the brushes and the commutator (that's what i usually do), but this is a pretty delicate and somewhat complicated procedure since you have to open up the motor, clean it and then put it back together in a correct way. I wouldn't recommend doing this unless there is absolutely no way to obtain a new motor (if you are truly interested in learning how to do it, post me a message, i'll explain it).
c) the main power switch has oxydized contacts, which means that the voltage on the primary of the power transformer is a bit lower, and, consequentially, all of the secondary voltages are lower, too. I know it may sound weird, but i had some players in which i cleaned the lens (on BOTH sides plus the mirror inside the laser), opened and cleaned all of the motors, but they would still not work correctly. Only after i've cleaned the contacts on the main power switch did they return to normal functioning. Obviously it's much easier to change the switch to solve this (if you have a spare one). You can check if the switch is the cause if you bypass it (you need to bring the mains voltage directly to the primary of the power transformer, but do it with caution as mains voltage can be LETHAL to you and your CD player - i don't recommend this either if you're not trained in electric safety).
These are just some of the possible causes. It may as well be that the real cause is something else, so don't take any of these for granted, they are just suggestions.
Anyway, i hope you can fix it (or at least have someone do it for you).
Good luck and best regards
3rq8 (triarcuate)
Posted on Jul 18, 2009
Grubhead
  • 5487 Answers
SOURCE: My stereo won't read the disks inserted in my CD player
All you can do is get a lens cleaner and hope that clears it up, otherwise you are looking at what might be an expensive replacement of the CD/lens/laser unit.
Posted on Dec 22, 2009
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
The disks won't spin/read. It powers up and gets internet connected but it won't read disks. I have a 60gb and do not want to get rid of it. Whats wrong, where can I get it fixed, and how much should it...
THe lens of your PS3 if failing and thus the reason it won't read discs. You can call Sony andhave it fixed, it's free if warranty is still good and $159 for out of warranty repairs.
May 17, 2010 | Sony Playstation 3 (PS3) Console
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
Dec 21, 2009 | Philips FW316C37 Shelf System
Hi i have a sony car stereo that plays the radio only!
what is happening on the display is the laser reading the disc if its not reading the disc your cd player is faulty more than likely the laser is either dirty or had its day,make sure there is compatible music data on the disc,also check all the sound options on the stereo.
Aug 25, 2009 | Audio Players & Recorders
Sony MHCG X250- is not reading the cd when inserted.
It might need to be cleaned with a cd cleaner. Otherwise the eye is bad.
Jun 19, 2009 | Behringer Eurolive B212A Speaker
My RCA stereo(RS 2620) will not read discs...
it might be the steiro cant read the disk because the cd is scratched or maby it cant read the cd cuz if you put the songs on a cd it might not read hope this helps!!!!
Jun 03, 2009 | RCA RS2620 Single Cassette Deck
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Disc Unreadable
simple format compatability issue.
you either don,t have the software on your computer.
Or the disks are unfinished or unfinalised, which means that there are no table-of-contents ( directory structure ) for windows to be able to understand the disks format.
Mike @ Compurepair.
Also the drive ( CD/DVD Rom ) may not be compatable with these disks. check your software read/write program, to see if the disks are supported.
Feb 14, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
117 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
