Question about Microsoft Windows XP Professional SP2
How to solve startup error rahulvirusprotection.vbe?
    President:
  • Microsoft Master
  • 1,996 Answers
Some malware has infected your system...
Reboot your computer and while it is starting up press f8 key repeatedly until the windows boot options screen appears. Choose safe mode with networking to start your system. Then go to www.malwarebytes.com and download the free malwarebytes anti-malware tool. Install it and update the definitions without restarting your system. Run a quick scan and remove any problems it finds. Only then restart your system normally.
If you cannot install MBAM for some reason in this way, you can create a boot disk that will run the program on your system, by following the instruction in the malwarebytes support forums here.
If you're not comfortable following these instructions or for some reason are unable to run MBAM, please open a request for support here and an expert in malware removal will walk you through the process.
Alternatively, you can follow these instructions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jan 06, 2011
ERROR CODE **E00000-00 IS DISPLAY IN MY CANON PRINTER IR2420 SO WHAT CAN IDO TO SOLV THIS
Startup error
The temperature detected by the main or sub thermistor does not rise to the specified value during startup control. - Check the fixing film connector. - Replace the fixing film unit. - Replace the DC controller PCB.
Dec 04, 2014 | Canon Office Equipment & Supplies
Is setup.exe.vbe safe to run?
probably not. .vbe means Visual Basic Encoded script. It seems as though someone tried to camouflage their script with a familiar filename (by prepending setup.exe in front of it. Is this on a CD or a file you received in email or downloaded?
Feb 04, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I am using a Transcend 8GB USB Pend Driver. when i scanned it, it showed me that, find "rahulvirusprotection.vbe". Hence i delete it immediately. After deleting the virus, i tried to access the...
It is virus which uses autorun feature of the removable devices such as USB Pen Drive. These type of viruses usually have two files. (a) autorun.inf and (b) the executable (.exe) or script file. Some Antivirus programs delete the exe file but the autorun files remains. In your case, the exe file (rahul's virus protection.vbe) has been removed but the autorun entry is there, which is run everytime you try to access your pen drive. First, plug-in the drive and DONT OPEN IT. Open 'My Computer' , right click the pen drive and choose explore. (This would by-pass the autorun feature).
Download Flash Disinfector and save it to your desktop. Double-click Flash Disinfector.exe to run it and follow any prompts that may appear. The utility may ask you to insert your flash drive. Please do so and allow the utility to clean up those drives as well. Wait until it has finished scanning and then exit the program.
Reboot your computer when done.
(Flash_Disinfector will remove any autorun.inf files, create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran it. Don't delete this folder. It will help protect your drives from future infection)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | Office Equipment & Supplies
How will solved script error "c:\windows\systems32\rahul"svirusprotection.vbe"
Rahul'sVirusprotection.vbe is a virus.
Follow the given steps to get rid of it
1) In Windows Explorer
Go to Tools -- Folder Options --View
Show hidden files and folders ---check this one
Hide prorected operation system file --Uncheck this one
2) Go to System Directoty ex: (C:\windows\ system32)
find this file "Rahul'sVirusprotection.vbe" and delete this one,
if u can't do that following the below steps
1)open the TaskManager(press control+Shift+Escapte key) then in
process Tab find ths Process "wscript.exe" and delete this one
or
2) using Unlocker 1.8.8.exe (search in Google site) for delete this
file
3) Type Regedit.exe into RUN Command
HKEY_CURRENT_USER\ SOFTWARE\ MICROSOFT\ INTERNET EXPLORER\MAIN
[Window Title = ""]
[Start Page = "www.google.com"]
HKEY_LOCAL_MACHINE\SOFTWARE\ MICROSOFT\Windows NT\ CurrentVersion
\Winlogon
[Userninit = "C:WINDOWS\system32\userinit.exe"]
Dec 22, 2010 | Computers & Internet
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Whenever i started windows it shows a warning message as can not find script file "c:\WINDOWS\system32\Rahul'sVirusprotection.vbe" how can i solve this problem? Is it a virus?
Follow below steps:
1. Click on Any folder.
2. Click Tools - Folder Options - View - Hidden Files & Folders
3. Mark Show hidden files and folders
4. Unmark Hide extensions of Known file types
5. Unmark Hide protected Operating system files (Recommended)
6. First two files were seen on my flash drive : Rahul'svirusprotection.vbe & autorun.inf
7. Click on the properties of both file and unmarked Read only.
8. Clicked Apply & deleted both files.
9. Searched for Rahul*.* on hard drives.
10. Click on the properties file and unmarked Read only deleted the file.
11. Now LORD RAHUL COOL is out of my browser.
Or try this:
If the error message is
"Cannot find script file C:\Windows\System32\Rahul'svirusprotection.vbe".
Create a new notepad document and open it, Don't type any thing in it, leave it empty and save it as "Rahul'svirusprotection.vbe".Then place this script file in "C:\Windows\System32\" and restart your PC, your error will be gone...
Oct 20, 2010 | Computers & Internet
Can not find a user manual for lenovo computer
try this link:
http://static.compusa.com/pdf/Lenovo-3000-J115-Type-7387-PC-Hardware-Guide.pdf
hope this solves your problem
thanks
RAhUL_hunk
Mar 09, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Startup hang
You will have to download this and make a repair cd on another computer.
Here is a site for a :
Master boot record repair kit http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62978&velxr-layout=printLenovo
Jun 28, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Microsoft Windows XP Professional SP2 Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
