Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Trying to vacum the stairs, no suction from the hose
chrispurs1
  • 372 Answers
SOURCE: no suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Posted on Jul 05, 2008
SOURCE: no hose suction
Clean your round filter and make sure there is nothing in the elbow tube in the bottom/back of the vacuum.
Posted on Feb 07, 2009
  • 389 Answers
SOURCE: dyson vacum cleaner lost suction
Forgive me if I'm thinking of the wrong model, but I think the DC14 has a short length of clear plastic tubing between the floor head and the fixed vacuum pipe-work. This tube can split and let air in which, of course, reduces suction at the head. You need to inspect it very carefully, as the split is often where it's really difficult to see!
If this is the problem, a repair with tape is possible but rarely completely satisfactory. A new bit of tube is the best solution.
Posted on Apr 08, 2009
  • 389 Answers
SOURCE: my hose suction works fine but the vacum itself
On the underside of the machine you will see a short length of clear plastic tubing with spiral reinforcing. Often this gets split, allowing an air leak. If the split is bad, there will be almost no effective suction at the brushbar. If that's the problem, a new tube is simple to fit.
Posted on Aug 16, 2009
Vacuum Guru
  • 78 Answers
SOURCE: vacum is fine just no suction on attachment hose
Hi there, I see this problem pretty often because where the hose joins the machine proper there is a slight reduction in airway size. I have made a video to show you how to remove the hose so take a look at that. If you find a split in the hose you will need to buy a new DC07 hose because it will reduce suction ans cause blockages more frequently.
Posted on Feb 27, 2011
Loss of suction in hose
your hose is blocked get some thing long and thin push it done the hose and try and clear it
Dec 17, 2013 | Dyson DC40 Multi floor Upright Vacuum...
There is no suction when using hose. (Edging)
you have blockage in the hose or the vacum is not in its upright position to enable the suction to the hose..
Best regards
CK
Mar 06, 2011 | Hoover U6630-900 WindTunnel Bagless...
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
c...
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
No hose suction
Jan 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
15 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
