Sony VGN-SZ470N Lap top will not power up -The charger green light is on. It has been plugged in- tested the outlet- Tried a second charger just to be sure. No charging light on the computer Just dead Held down the power on switch for as long as 1 minute.
  • 425 Answers
Try removing the batteries for a minute and put it back. try to power it up again.
it happened to me may times now, and i hope it will work with yours also.
try it...
Posted on Dec 29, 2010
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
Sony battery and power light stay on
Remove main battery and power up, next! sub out the ram one at a time and test, remove the second piece and put the first one back for a valid test.
Mar 22, 2012 | Sony VAIO VGN-CS215J/W Notebook
Cannot get power to a Sony VGN-SZ470N. Yes its plugged in to a hot socket.
Remove the battery form laptop and insert it again and see if it s work or just power on without the battery.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Sony VAIO VGN-SZ470N/C PC Notebook
Sony VGN-FW170J Not Turning On. Power supply good, tested with multimeter & with another laptop. No LED light, lighting up when connected to power supply, also tried with and without battery. Nothing...
If the PSU is good and there is no lights coming on when you either plug in the charger or attempt to turn on the machine then it's simply the motherboard.
There is a good chance that a few transistors blew out. Laptop repair or even motherboard replacement is very expensive. If the computer is still under warranty then take advantage of the product defect and get it repaired or replaced.
Jun 07, 2010 | Sony VAIO VGN-FW170J/H Laptop
The power light come on in my vaio lap top but wont start
boot files / Win files corrupt....
re-install OS
visit my site
www.sureshayyar.110mb.com
get all details on installing Win XP
pls leave a feedback...
May 10, 2010 | Sony VAIO FZ Series VGN-FZ140N/B Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Sony VAIO VGN-A690 not powering up
Press and hold the power button for about 20 seconds and then press the power button again. If your notebook is set to standby or hiberbate it may have lock up the computer. Hope this hepls
Feb 01, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Wont turn on
plz re insert laptop battery
put charge the lap top
n also i tink there is problem in power supply.
for help call me +919441133420
kishorechowdary
May 04, 2008 | Sony VAIO VGN-FS640W Notebook
Computers & Internet Logo
David Payne
David Payne
