Question about Brother Office Equipment & Supplies
Brother intellifax 1270e I need to change my baud speed and turn the ecm off?! to communicate with digital faxes
flopez
  • 161 Answers
SOURCE: Any way to manually LOWER the Fax Connection Baud Rate?
Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
Posted on Nov 01, 2007
ctf1800
  • 4402 Answers
SOURCE: sending fax
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Posted on Jan 10, 2008
IB4G2008
  • 3587 Answers
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
here's a good place to start..see the user manual at the bottom of this page
Posted on Jun 01, 2008
alvinbga
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
How to adjust baud rate on brother intellifax 1270e
I have just e-mailed you the manual, if in case you did not get it or anyone else stumbles on this question, you can download it here:
Brother Intellifax 1270e manual
Aug 26, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
How to cancel a fax in progress on a brother intellifax 1270
If it's from your side just turn the device off, if it's from the other side (if you sent a fax over to someone) then it's in their memory and you can't do anything about it. For further help consult the manual here: Brother Intellifax 1270e manual
Jul 29, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
Clear brother fax 1270e memory
Unplug it and leave it for 12 hours without any connection and power, it will delete everything inside it. For further info check the manual here: Brother Intellifax 1270e manual
Jun 14, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
Need to lower baud rate on my Brother 4100
The baud rate or communication speed of the Brother 4100 Fax is not selectible by the user. It is factory set to begin at 14.4 (the highest speed) and fall back in increments until reliable communication is established.
Oct 20, 2009 | Brother IntelliFAX 4100 Laser Fax
I cant figure out how to lower the baud rate on a brother intellifax 3800
On Brother machines the baud rate is set automatically during the handshake with the other machines, turning off the ECM usually helps when you are getting a lot of communication errors.
Sep 01, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Need the baud rate to be 9600
fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Dec 03, 2008 | Brother IntelliFAX 2800 Laser Fax
How can I change the print quality of faxes received on my Brother IntelliFAX-1270e machine. Paula
You normally can't control the print quality of what you receive. You might try a new toner cartridge.
Aug 14, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
102 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
