Error code F71 - Washing Machines
  • 4 more comments
  • joyservices Jul 28, 2008
    when i connect the power to de first card in fron and after the data cord the machine sound and present the error code F71
  • Anonymous Oct 14, 2008
    Door stuck shut & error 7 keeps coming up on digital display?
  • Anonymous Nov 15, 2008
    Yesterday the washer buttons lit up and it let me select a cycle, but the door-locked button didn't light and the washer wouldn't start. It would just beep three times. Today, it won't let me select anything, and it's flashing "F71".
  • Anonymous Nov 23, 2008
    I have the same problem with my WFW9400S - had a tech come out and tell me that it would cost close to $600 for new control board and labor. The unit is now 14 months old.
  • dawgoneit Nov 25, 2008
    Was washing cold high-spin heavy-soil load, one hour into wash machine stopped with F71 error. Instructions say to press cancel twice - this did NOTHING. Machine will not start. It it dead. It is only 10 months old.
  • vindaloser Jan 05, 2009
    F71...WHAT THE HELL IS THIS???
  • 15,935 Answers
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
  • blueextc3221
    blueextc3221 Sep 09, 2010
Troubleshoot washer code reads F71 no displays
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Jan 03, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
Regards.
Dec 11, 2010 | Kenmore 47081 Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
860 people viewed this question
Top Washing Machines Experts
